New WoodChat!
Question: Sources for Brass Handsaw Screws?
Christopher Fitch Memphis
So I'm working on a Disston D-8 Handsaw rehab(I've narrowed the construction date down to between 1928-1940). I picked it up for $4 at an estate sale. I expect many people would have not picked it up but it was cheap and it's not in that bad of shape.
The blade was covered in rust/dirt but it cleaned up ok (certainly good enough to use) and the handle was intact but it only had the medallion and two screws.
I did a pretty thorough search looking for brass screws from lots of tool suppliers, but I just have not found anything. I can find brass split nut screws for backsaws but none for handsaws other than nickel-plated ones.
I've tried two separate sets of Disston screws off of Ebay, but those are either nickel plated for a backsaw or brass plated and the plating is almost gone.
I really don't care that much about authenticity but I do want brass and I do want some that fit!
I have no desire nor the tools to make some and Chicago screws I find online lack the crucial square part of the bolt that locks the screw in place in the handle.
Any one have any ideas?
P.S. I'll post a few pics when I'm done with it. Going to try to fix the kink Bob Smalser style and then take a shot at sharpening it. Assuming I can make all this work, it will be a good 26" 8 point crosscut saw.
Re: Question: Sources for Brass Handsaw Screws?
Jack Guzman from Maine
I don't know what the situation near you is but here in southern Maine old saws are plentiful. Every yard sale,flea market or antique shop has old handsaws for one or two dollars on a back shelf or in a barrel somewhere around. Alot of these are bent,wore out or pitted to the point where they are not much use. You could find the screws you need by shopping around.---Jack
Ha!
Tony - Memphis
We are in a woodworking desert here! We don't even have any hardwood dealers anymore!
Re: Ha!
I have a bunch of old saws I'm never going to do anything with. What are the dimensions of the saw screws you need. Maybe I can help.Got a picture?---Jack
My reply for Tony was meant for you. I have a bunch of junk saws and even some saw screws and nuts. Let me know what you need and I'll see if I have it.---Jack
What Tony Said...
I'd say that this one would be a saw that normally would have been scavenged for parts in other parts of the country.
Thanks Jack.
I'll try to remember to post some pictures later tonight.
A few pictures
Here's what it looked like at the start:
" border="0" alt="">
Here's a closer look at the handle:
After cleaning, here's what it is now:
Here's two close-ups of one of the saw nuts/bolts:
Looks like...
some images got eaten. I'll try again
Saw cleaned:
And a nut/bolt
Re: Looks like...
It's late but those pictures should do it. I'll look tomorrow and get back to you. Those look common. I should have them. Be aware of one thing. When those screws are out for any length of time the screws may not fit back in without a little adjustment. Wood moves and the holes might not line up just right.---Jack
I have a pair of screw/nuts that appear to be the same as the ones in your picture.You're missing two right? Email me your address and I'll send them to you.---Jack
I emailed jack.
Thanks for this..i really really appreciate it.
No problem
You are welcome. I have gotten my share of help from this place over the years. Just passing it on.---Jack
Re: No problem
Michael Brady
TGIAG.com has new ones that are much nicer than the originals, in machined brass.
yea but
Those are nice but they wouldn't look right on a refurbished antique.---Jack
They fit
Hey Jack, they worked! Thanks again.
Here's a final picture.
Next step: sharpening. I've never done it before but it's long overdue for me to learn how.
Re: No problem
I considered those (Alamo Tools sells them too and I'm certain there are others). However, just as Jack mentioned, they just won't look right.
Also, I'd have to do some work on them including rounding the heads over and they might not even fit quite right.
Nice Restoration!!!
Ron in Sterling, CT
Good Luck with the sharpening.
Ron
Re: Nice Restoration!!!
Thanks Ron.
Not too bad for a $4 pickup. Though you can't see it in the picture, there is still an etch though quite faint.
This will be the third one I've done though I will say this one was pushing the limits. I think I might have to skip ones that are missing nuts just as a general rule.
