New WoodChat!
LV Small Plow Plane Fix.....
roger lance
There has been conversation regarding the depth stop on this plane and some experiencing slippage. LV has a remedy in the offing.....but here is another simple fix......
Just place a small strip of self-adhesive sandpaper in the depth stop grove (I'm using 220 grit)......it slips no more.
I'm still very interested to know thoughts of those who have undergone the modification of the skate and have used the new blades. Please post a review once you've experienced this update.
Re: LV Small Plow Plane Fix.....
I posted this on WoodNet some weeks ago ...
Pics today of the new depth stop while making slips for drawers ...
Small Plow Plane ploughing a groove ..
The new depth stock is excellent. I've been using it for a while now, and it has been reliable. I am still inclined to use the slot I cut in the screw head to lock it down a little more snuggly, but that is now just a habit speaking.
Basically, Lee Valley designed a small add-on to shift the position of the screw. It now longer tightens a collar over the depth stop shaft, but enables the screw to directly contact the shaft of the depth stop.
A hex bolt holds the add-on where the old screw held down the collar ...
Screw centred on the shaft ..
