New WoodChat!
Have a question? Ask Woody!
A dovetail sawing aid
While a few just look at the side of a drawer and commence sawing the pins or tails, depending on what one does first, it is more common to mark the pins or tails and use the marks to guide the saw kerfs as shown in the first picture. Drawing all these lines is a time consuming task.
We have a lot of small box makers in our area. Apparently they sell well at the craft shows. Recently I encountered two of these makers at separate venues demonstrating their box making. Like me, they were each tails first practitioners. In spite of the fact these people cut dovetails daily to assemble their boxes, which should have kept them in practice, they used a sawing aid I had never seen used by any furniture maker.
The aid was a block of wood that engaged the top of the board to be sawed. It was used to align the saw at the saw mark perpendicular to the face of the board. After the kerf is started the block is removed and the sawing down the guide line continued. Sawing perpendicular to the board is a task I had never found daunting. Never-the- less this sawing aid stuck in my mind in spite of the fact it seemed to offer no benefit to me.
While sawing the dovetails for a carcass I recalled this aid as I was tediously marking out the dovetails. With the slight modification of angling its end about 14 degrees it could aid me by eliminating the need to draw all those saw guide lines. All that is needed is a scribe line to establish the depth of the dovetail and a small mark on the top edge of the board to indicate the position of the saw kerf. The guide block is positioned at the mark defining the tail and the saw aligned with the angled end of the block. My LN saw saws in whatever direction it starts so after a couple of strokes of the saw I remove the guide block and continue sawing down to the scribe line. The time saving was significant.
Re: A dovetail sawing aid
roger lance
Bill.....go to YouTube and look up David Barron - New Magnetic Dovetail Guides. He is the man that made that guide board we talked about some time back.....and also a version of the dovetail aid you've shown.
Different emphasis
I found UTube videos rapidly consume my limited monthly download quota. It has to be compelling to download one. But from the title the emphasis is different. What I am finding advantageous is not this things ability to keep the saw pointed in the proper direction. I passed that hurdle years ago. Rather its elimination of most of the marking time is what I find useful.
And, who would buy something that I made in a minute from a piece of maple in the burn pile?
Re: You'd be surprised
david weaver
You'd be surprised by the scads of things that are sold to people as shop aids that you could otherwise make on your own very quickly.
Expensive dovetail markers, marking knives, sawing guides, marking aids. A lot of them offer the promise of instant success, but they also promise spending a lot of time on things that become easy down the road.
I mark the tails on a board on the end with the pencil, but never check the angle on the dovetail saw as I don't generally leave dovetails exposed. You can do a pretty good job judging the angles to the eye if you don't rely on something, anyway.
If I were putting the dovetails on the outside of the case and leaving them to show (something I've never done), I'd still mark them, I guess.
I'm presently trying to decrease the size of my junk pile, which includes all kinds of crap that I've bought over the years that nobody really needs. I'm glad I didn't buy a whole bunch of little dovetail markers and marking knives.
Paul Sellers slight variation
Ron Harper
He teaches a technique for cutting multiple joints of the same size. Get a scrap the same width as tge stock. Layout the tails and cut them. About half an inch too deep
Clamp the scrap piece behind tge stock and use for a sawing guide. In theory it makes the joints identical. And cuts out a lot if layout time
Re: Just FK them
TomD
Just FK them by eye. I have done that on furniture pieces and I did a really bad job the first time I did them, getting them all backwards where the half pins where large, not in the sense that they didn't grip, but the spacing was wrong. Still nobody has ever said anything about them and they were about as bad as it gets. People often talk about letting flaws show through indicating it was hand work. Well I don't go for that, but microscopic dissimilarities in spacing of tight joints, I might go there. The problem with jigs is they stop the learning process, which is fine where required.
Another option is to lay-out off the chisel. There is a good video method on that you (well others) can get from season one of Tommy Mac's show, the step stool video. I always lay out off the chisel when I do stuff, but I mark also.
I have four levels. I FK all utility stuff; I do a regular layout for fine furniture; For studio grade stuff I do a knife layout (not 100% sure this improves maters); and then I have the Leigh jig that I rarely use, but I can use it and just recently bought two routers for it. Kinda figuring I might have some industrial production to do.
