New WoodChat!
Medicine cabinet, second build
Brian Holcombe
I'm building two medicine cabinets and the first one is nearing completion. I've created a door for it, which I'm fairly happy with, but have decided to create another design for the second cabinet, and if it is a success possibly replace the first with this second design. My feeling being that the door is just a bit too sleek for the cabinet.
So this is the finished door, less handle, installed into the wall....less drywall work.
So, I've put that aside to do some contemplating on how to do the handle and have begun the second case, detailing the build a bit more thoroughly.
It starts with a good bit of sawing and resawing, my goal being to get the material down to it's best sections and retain enough of it to get the majority of the cabinet out f a few board feet.
Onto flattening. Not a whole lot of material to work with so I ran the Jack plane long grain.
After creating my reference face and bringing the other down to thickness I finished planed. Nearly nothing for tear out and I removed the tiny bit that I had in about two swipes.
Roughing them down to width.
Six sides square
Then onto dovetailing. Minor goof in that I should have retained the rear mitered on the top of the case, since I eliminated them I have to cut a stopped dado.
I've been basically eliminating paring blocks from my repertoire, but in this case the miter is quite critical, so I decided to make one up for it. I did without on the first case and decided that my miters needed a bit more perfecting.
In the process of cutting these dovetails the long 1/2" bolt in my bench gave up the ghost. I decided that rather than replacing it with a larger bolt that it was time to provide another solution;
So far so good, much firmer hold on material.
Miters looking good, and I will pull the into proper alignment when I glue up
And my dovetail work, which will be buried in the wall, is looking good to my eye.
And finally what the end user (my wife) will see;
Evidence of dovetails to me...
Re: Medicine cabinet, second build
roger lance
Brian.....I really enjoy following along with your builds.....great work, great photography......and a very interesting bench modification.
david weaver
Top shelf stuff. I built a medicine cabinet to fit an oddball size hole in the wall in my 50's era house, but it wasn't put together as nicely as those!
Brian Holcombe
Thank you both!
Hopefully the changes I have made to the second one will do it a positive. My wife loved the first but wasn't keen on the door.
Thanks for these build shots
Your discussions of what you're building, why you are building it that way, and how are really great!
And I like your shooting board design: simple as can be, and easy to store. It would sure solve a problem in my shoplet, which is crammed full already.
Re: Thanks for these build shots
Brian Holcombe
Thanks Bill!
Hah, glad you like the 'shooting board'. :)
Brian Holcombe
I'm continuing this build on my blog, in order to simplify multiple postings
https://brianholcombewoodworkerblog.wordpress.com/2016/02/03/medicine-cabinet-build-casework/
In this post I'm doing the layout and detail work of the inner case and begin dovetailing the outer case.
Check it out and give me feedback, if you guys don't mind the extra click it saves some work on my end, but I appreciate any feedback.
