Italian Bench
Recall that recently we built a portable bench based on a Moravian bench at MESDA. I found a similar bench in a flea market in Florence.
Italian Bench
Re: Italian Bench
roger lance
I know you didn't make an offer......it has a tool tray !!
Re: Italian Bench
Warren in Lancaster, PA
I used to have an old frame like that which I used as a portable bench with a heavy plank laid on top. Two permanent end frames, each made of four oak 4X4s and two long stretchers 3X6 with tenons and wedges at each end. I think it is a common design, and I have recommended it occasionally to others for a bench that can be easily moved.
Did it fit in the carry-on luggage?
Tail doves!?
Charlie belden
The end of the shoulder vise arm appears to be "tail doved". Not as much mechanical strength in tail doves as in dovetails. Maybe too much vino before cutting them : )
Re: Tail doves!?
TomD
Half blind? The clamping load, if I have the right piece is applied in such a way that the strongest construction under load would be no joint at all, with the crosspiece, that has the screw in it, pressing on the sliding jaw. The dovetail is just for withdrawing the jaw.
