Re: Nice one David!
david weaver
Thanks, Derek (you won't be surprised about my handle comment given your appreciation of it). I didn't take many pictures of the plane, I guess I didn't think about it. I took one to send to Brian as the handle was drying, and it turned out that putting it in the sun for even a short time (to keep it warm so the liquid hide glue would dry hard) was a mistake, it developed slight cosmetic surface checks on the endgrain in escapement and at the back that it took some effort to reclose. not a hot day here, either. It was in the low 70s (~24 celsius) and the checking was quick to happen since beech passes moisture out of its ends so fast - faster than I'd have guessed. Would've been no issue had I oiled and waxed the ends.
Anyway, picture here (before finish, of course - it's not a photo perfect plane, but I hope it qualifies for handsome - a term I'm borrowing from warren):
http://s1.postimg.org/wzu3jqia7/IMG_20150823_124200_682.jpg
It is (not totally, but proportionally) a copy of a griffiths try plane that I have with the handle sized up a little. 2 1/2 inch wide iron, 24 inches long, and as this was a dense piece of wood, 8 pounds (which is a nice weight). Common pitch (45 degree) bed, and a tall wear somewhere in the high 70s degrees, I think (never know exactly where it lines up because I don't have a pattern and things move a little from marked lines when you're finishing the plane and opening it up a little until it feeds reliably).
I think in pictures the handles a bit more upright than most I make, but it gives Brian the opportunity to tuck the top curve in a little and change the angle later if it should ever be uncomfortable. It's just what the griffiths handle pattern I used looks like, and it has a bit less of a hump in the palm than some more angled types.
The iron is something from sheffield (can't remember the mark), a little more modern but in the classic style (it's solid steel instead of laminated, but tapered). steel cap iron of the classic style, both NOS. Most of the old sheffield stuff is fairly soft, and it's no exception, but soft is no problem on a middle plane and they wear reliably.
The whole thing came up because I mentioned something about wanting a plane with a wood sole to brian when he was talking about cutting rebates, and I can't remember why, but the try plane came up and tossing my LN 7 due to friction came up. Inevitably that leads to trying to tell someone what to look for in a used plane and I couldn't spot anything good listed online, so I offered to make Brian a plane if he didn't mind covering materials since it's about the same amount of money as finding a good plane from a fair seller.
I know Brian dimensions by hand, and he's one of maybe a few people who would benefit from having a middle plane like this, thus the offer. I hope nobody gets the idea that I'm making planes professionally, because I'm sort of making what I want to make to satisfy my urge to make, and hoping for a home for it. When the urge goes away, I'll stop.
I do wish it was easier to find vintage planes of the type to point people do. They are so fine to use when everything is tight on them, but it's hard to find 150-200 year old planes where not much has been modified, most of the iron is left and the plane has been kept in a place that doesn't allow it to check up significantly.
