New WoodChat!
Grooves and rabbets in short and narrow boards
Joe shelton
What are good solutions, including appliances, for working treatments in the edges of short, narrow boards such as drawer sides?
I'm struggling now with dogs, stops and battens but am having a real hard time getting positive control of the workpiece.
I guess I need a sticking board, but I'd like to hear about some options for material control.
And happy Easter, too.
Re: Grooves and rabbets in short and narrow boards
Re: Grooves and rabbets in short and narrow boards *LINK*
JDK
I recommend Paul Sellers' clamp-in-vise technique:
Clamp-in-Vise
Jim in Burlington Ont.
Jim in Burlington
I also like double sided tape.
Hi Joe
I built a sticking board when I needed to make drawer grooves for tiny drawers. This has more uses than just grooves and rebates in small pieces.
The one below has since had a few minor mods, but essentially remains the same. It is adjustable for width if board, which is important when you need to use the edge of the bench to guide the fence.
Link to more: http://www.inthewoodshop.com/ShopMadeTools/AdjustableStickingBoard.html
Wiley Horne--So. Calif.
Hi Joe and all,
I think the main problem is getting clearance for the fence of the plough or the moving fillister or router plane.
One or more sticking boards is the answer. Like Derek's, or Sir Wm. did a long one suitable for everything up to long moldings. Well, I never did one. Too lazy I guess.
Drawer sides. I used slips on the most recent project, cause the sides were 1/4" and I didn't want to groove them an 1/8".
But suppose it's a drawer side 3/8" thick or more, but not thick enough to provide clearance for a plough fence, say. My strategy is to use dogs; I put the dog holes as close to the edge of the bench as I dared, so as to be able to hang narrow pieces over the edge to get fence clearance. If the pieces are too narrow to clear the bench edge, I just find a stick in the shorts pile a little shorter than the work piece, and put the short piece under the work so as to lift it up to make clearance for the tool's fence. I haven't had trouble doing without positive backing on the work, but if that arose, I would use a hold down to clamp something behind the work.
Wiley
a different approach - drawer slips
ian in Sydney
of course, the other way around this problem is to use drawer slips.
the groove can be cut in a suitably wide board and then the slip cut off the edge
the Schwarz http://www.popularwoodworking.com/techniques/joinery/about-drawer-slips
