Re: first spoon and a related gouge question
Matt,
I've made several spoons and ladles, and even sold some of them, all of them from seasoned hardwoods, but none recently.
Sleuthing from your posts, I deduce that you may be Matt Reagan, from Virginia. If you are located near the largest population center of that state, you might be interested in some tools imminently applicable to the carving of spoon bowls that are being offered at an old tools auction in Damascus, MD in a couple of weeks.
The organization is PATINA. www.patinatools.org
The auction announcement is here: http://www.patinatools.org/auctioninfo.asp
The auction item list is here: http://www.patinatools.org/auction_2014/2014_WebList_Sorted.html
The lot number is 169.
Back to spoon generalities: Carve the bowl first, since that operation puts the most stress on the wood stock. (There's nothing more frustrating than separating the handle from the bowl while hollowing. After you've done it once, you will understand.) If you want to use a gouge with a mallet, it is most efficient to remove the abundance of the stock across the grain, where a gouge with a larger sweep is more efficient than the smaller sweep you would use for finish shaping, with the grain.. A mallet helps a lot. Mallets do not transfer forces efficiently to bent gouges, because the gouge's handle tends to flex, a lot. You would be better off using straight gouges, especially for the rough stock removal.
For finishing the bowl, inside and out, a selection of curved card scrapers of various radii are very useful.
For help in spoon carving techniques and inspiration, check out Barry Gordon, , e.g., this page on his web site: http://barrygordon.com/making-spoons-guide/
For advise on sharpening gouges, you can't find a better instructor than Mary May, and Chris Pye's books and videos on the subject are also very useful.
If your philosophies do not limit you to hand tools, my preferences for roughing in the bowl are Kutzall burrs. Of course, use of a bandsaw for rough shaping is de regueur.
For example, http://www.ebay.com/itm/like/281266661119?lpid=82 and http://www.artcotools.com/kutzall-bur-3-4-dia.-bn34.html
To drive these, I use a 4" Makita GA4530 4-1/2" angle grinder and a pneumatic Grex AR368, followed by a Grex AOS368 angle die grinder/random orbital sander for sanding.
http://www.amazon.com/Grex-MR368-Air-Powered-Inline-Grinder/dp/B000HHRL80
Note that I am providing the links to these products only to illustrate the types of tools I use, and I DO NOT endorse any of these particular merchants. They just happend to be the first examples that Google found for me. I bought the tools I use at the Orange Borg and at a woodworking retailer where I used to work.
If you go this route, wear your eye protection, hearing protection, breathing protection, and heavy gloves.
