We value your privacy.
This is another of those scrap to tool projects that can be made quickly.....and hopefully accurately. Its no secret that I'm a hybrid woodworker with a power mitre box and a jig for that box for small parts but I believe that I might get more control and better cuts with my Dozuki Z and a simple wood jig to hold the stock and guide the saw.....we've all seen those.....but what I'm showing tonight is my way of helping to hold the saw in the correct orientation when making those initial cuts into the jig.....the better this can be done, the more accurate the jig. So what I did....
was to clamp two guide boards into the jig to guide the saw. Seems to have worked well....
This jig can be securely held in your shoulder vise and should come in handy.....
Not to rain on the parade but it looks like your cut was off-vertical, in one of the photos, based on the pencil line as seen in that photo. This might result in a slight and unintended compound miter. Just thinking out loud.
Very good eye sight.....you're correct.....the other 5 cuts were vertical.....made some test cuts seemed OK but will be monitoring this slot for deviation.....do not know why this happened but will soldier on.....and if it does become an issue, there will be more scrap and another hour to go for 2.0
I think I understand, in general, what you are trying to achieve, but I'm not so sure I follow everything that's going on in your photos.
First, I assume this works because your chop saw is "dialed in" and the cut in the saw guide block is very very close to 90° vertically and 45° degrees horizontally. I further assume the two halves of the guide block are closed up on the saw plate so there is very little opportunity for the saw to wander.
But, I don't understand how the clamps are working. Is your jig exactly the same thickness as the center (bottom) block of the miter box you are building? Do you rely on the flexibility of the front and back blocks to hold the jig in place while you saw the slots?
Since the saw back has some flexibility, the plate has even more flexibility, and the kerf in the jig can get wider each time you make a cut, it appears that the kerf you are sawing in the miter box has a lot of room to wander.
I will suggest a couple of strategies that might help the accuracy of your jig and therefore the accuracy of the resulting miter box. First, make the stock for your jig five boards wide, and glue it up in an inverted U-shape. Set the two pieces of the jig over the whole miter box. That insures the kerfs are aligned over the complete depth and thickness of the miter box, leaving a lot less room for the saw to flex. Also, you can then clamp the halves of the jig to one fence each (one to the front fence, one to the back fence). This keeps you from distorting the fences when sawing. Second, stick some shims to the plate of the saw, just enough to make up the difference between the thickness of the saw plate and the set of the teeth. You might try some adhesive back UHMW tape, if you can find some in the right thickness, or some brass shim stock and 3M 77 spray adhesive. You will probably have to taper the entrances and exits to the kerfs in the jig, to keep from pulling off the shims.
First, your assumptions are correct....my chop saw is dialed in and produces very good 90° and 45° cuts to make the guide blocks.
Second, in order to get the guide blocks (which were the same thickness as the jig bottom board) into the jig.....I sanded them slightly and added the clamps to eliminate any possible movement.....there would be some distortion of the outside fences but we are really getting into some very small amount of distortion.....something that a metal worker might be able to measure.....and the jig being wood, there may be distortion with humidity fluctuations anyway.
As far as those kerfs being wide, I had a little difficulty getting the saw back in the kerfs to make the test cuts I mentioned above.....again, being that this is wood, I expect that there will be wear and tear.....and eventually, you might replace the jig when you are no longer getting satisfactory results on small stock pieces.
I'd like to see your version......I know what I've made can certainly be improved.
Well Tom.....some of us (me for example) are not able to freehand perfect 45° and 90° saw cuts on small stock with a dozuki or any other hand saw for that matter and we rely on an aid/jig to help us out.....you must be an exceptional craftsman given you can't relate to the basic purpose of this simple device.
Well, I can't say I have ever used one. So maybe I am missing the point. I mean, LV sells then for cutting dovetails, but many people seem to manage those, so I doubt I am in any kind of minority.
Franz Klauzs said that cutting square by hand without any marking was a very beginner skill, and he knows a thing or two about learning. One advantage of an apprenticeship is that one gets a privileged exposure to the craft. But one also learns from a hard task master just exactly which skills one is not expected to drag one's heels over, in the learning of. Or that was how I took it.
Anyway, don't most people around here own 4 or 5 shooting boards?
I frequently make small picture frames and moldings that have either curved top edges or other molded profiles. Sometimes the materials and/or the surfaces are delicate, as in prefinished frame stock, and a power miter saw would be destructive or dangerous. Marking out on molded stock like this is usually difficult if not impossible. No doubt, I could eyeball a 45º cut with a handsaw and get it pretty close, but an accurate miter box and a smooth-cutting saw, Japanese or Western, could make it possible to get finished miters without having to further shoot or process them. Making the miter box to that level of accuracy requires some sort of controlled guidance for the saw.
First, the only reason I posted this was to show the guide blocks which might be of interest/help to someone thinking of making a similar jig. The jig itself was made "down and dirty" and can certainly be improved.
Second, the jig was made to help me make accurate, repeatable, predictable, and controlled cuts in a safe manner. In that regard, aren't just about all tools in woodworking that have a cutting device (from a tablesaw to a handplane) designed to deliver the same qualities ?? In other words, woodworking tools are essentially jigs......and I have to wonder why someone would say its acceptable to use some jigs (tools) but not others !!
Third, I think people should use whatever they want to use to do their work.....its an individual decision.
There is precedent for the use of guides in Japanese woodworking. I’ve seen numerous examples of shop made guides made by Japanese woodworkers like these:
There are also examples of jigs used to aid in paring to a 45º or other preset angle.
These aren’t exactly the same design as Roger’s, but to say that Japanese woodworkers never used such aids is not quite accurate.
Some years back, I made a miter block from a scrap of architectural door jamb, which had a nice built in rabbet, for cutting some 1/4" square picture frame stock to make a fridge magnet out of a goopy sentimental card (Valentine's Day present). Miter blocks differ from boxes in being open on the front, and were a classic British tool for small molding stock. Miter blocks look ike this:
The door jamb stock looked something like this:
and this is the specific information for "northern region" customers of Kelleher, the locally dominant molding company: http://kelleher.com/product/2/region/N/item/4859 . Any contractor's lumberyard and, no doubt, some big boxy stores and "civilian" lumberyards will have some version of this in stock, and a foot or two shouldn't cost much.
I made the cuts, with a gent's saw, by verrry careful marking out and sawing on two lines, while holding my mouth right (that last step was, my father would always assert, the most important one). Looking back, I'd have been smarter to use another scrap to serve as a stop/jig to hold the saw vertical, but I was in the mood for a high-wire act that day.
Alas, I allowed the pine miter block to get wet, and it got ruint; I need to make another one some time.
Classic metal miter boxes, like the M-F Langdon series, in good tune, can shave a saw-kerf's width of wood from a piece of stock, and are quite precise. They're also rugged as a Mercedes off-road vehicle, so they often come in good tune from the yard sale where you find them. But they're not easily found everywhere in the country, so the miter block might be a good choice.
I have seen this technique used in a lot of YouTube videos of Japanese woodworkers and I have always wondered how do you keep the plane from cutting the surrounding wood. Are these devices just used until they are worn out and then replaced? Or is there some techinque of using the plane that would avoid cutting away portions of the jig?
Your workpiece sits just proud of the jig and the last pass just barely grazes the jig itself. Plus the bearing surfaces are made of a harder wood, such as endgrain oak, which tends to resist the edge more than the typically softwood shoji parts.
That's my experience and my observation. Some of the miter-donkey guys around here can probably add to or refute this.
Most of the time I just mark with a knife and saw freehand to the lines. Even so, some pieces, such as mouldings where the lines are difficult to mark and see, benefit from a bench hook or mitre box.
Mark Harrell at Bad Axe Tool Works sells a well-designed bench hook. I use the same design (ergo, my bench hook is well designed ) ...
The only issue I have with this affair is that the saws used need to have the same thickness plate and minimal set otherwise the kerf is progressively widened and the saw can be forced off line.
I made a small mitre box for small mouldings. This is more flexible with saws - can use different kerf widths and Western and Japanese saws equally - as the guide is built with rare earth magnets ...
I may have an explanation for why the backside of my cut on the left hand sided mitre was off.....ergonomics (as Derek would point out).....being that I'm right handed, I was probably not in as good a standing position when I made this cut into the jig and was putting some pressure toward the right on the backside of the cut.....as the jig is being held in my shoulder (face) vise, I should have physically moved myself around the end of the bench and then made this cut with a more natural movement that would favor my right hand.
