New WoodChat!
A simple tool making project.....
roger lance
My apologies to Derek for taking the viewer from a high skill project to a project most can do in short order. I just made a couple of marking knives with blades by Pfeil Swiss Made that are sold at Woodcraft.
Given that I'm unaccomplished on the lathe and not very creative to boot, I used a form for the handles that comes with their pre-made marking knife.....comfortable and gets the job done. Now, I think I'll go back and look more closely at that chair build.
Re: A simple tool making project.....
Simple, yes; and nice, too!
Hi Roger
They look like they will work very well.
I am curious to know how you - and others - sharpen knives like this, and smaller?
roger lance
Hi Derek.....Happy New Year to you and yours.....I've not owned or sharpened blades like these before but I was thinking of adding to my sharpening kit with a set of DMT mini sharpening hones which are small handheld tools......place the blade flat on its back on the edge of a board with one edge of the blade just over the edge of the board and move the hone in a singular pass over the blade's edge.....remove any burr on a water stone with the blade flat on its back.
But....LOL....I want to ask....how do you sharpen such a blade ?
Re: Freehand
William Duffield
I sharpen mine on a stone, freehand. If necessary, on a series of stones, usually coarse, fine and extra fine DMT diamond, followed by a single pass across the back with the EF, and drag it across a leather strop charged with green chrome.
I see no need to jig the knife blade, because, other than sharp and a relatively flat back, there's no real reason to get the bevels to any particular geometry or even to a precise bevel angle.
Hi Roger
As William describes, I simply freehand hone the edge on waterstones. This is easier if you hold the bevel face flat on the medium and pull it towards yourself.
The wide blades, such as the one you are using, are not difficult to balance. The ones you have to watch out for are the wee dovetail marking knives, such as the Blue Spruce. Dave Jeske has a nice video demonstrating how to do this.
Here are the ones I used to make (now made by Chris Vesper) - similar to the Blue Spruce...
When I started making these knifes, I ground the bevel freehand and then honed it again freehand on diamond stones. When I began to make them in larger numbers I developed a jig to grind the bevels, but I would still hone them freehand. The jig is in this article: http://www.inthewoodshop.com/ShopMadeTools/A%20Knife%20for%20Marking%20Dovetails.html
I suspect the blade you have is closer in size to the large Vesper marking knife. If so, and you have a Tormek or similar, you can also hollow grind the blades, which makes honing a 10 second affair. This is useful if you need to restore the V (which can be fragile) or the bevels have become rounded through honing freehand.
