New WoodChat!
Something different--Rocker/settee
Jack Guzman from Maine
A client requested a rocker that he could use for him and his girl to rock on their back porch. I searched for ideas and the closest I came was something called a granny rocker. Longer than I wanted and set up like a cradle that an adult could sit on the edge of while rocking a baby.
I decided to use some windsor chair features that I was used to and modify it.
This picture is what I came up with. All round pieces are ash,the seat is white pine,rockers are yellow birch,back rail is maple and the arms are cherry.The client hasn't seen it yet and it is as yet unfinished. I will treat it with a wipe on oil/varnish mix. If the client wants it painted I figure he can paint right over it. I think the wood is too pretty to paint.---Jack
Re: Something different--Rocker/settee
Bruce, a MN Galoot
That's really nice, Jack!
Tell me something. How do you join the arm to the corner post (or whatever it's called)? I'm at that point on a rocker I'm making for my granddaughter and while I have a solution, I don't particularly like it.
Tom
Really nice, though I gather the call isn't for a love seat... :)
I used a screw. I don't as a rule use any hardware in a chair but I repair antiques and that was the way it was always done so I hollow out the end of the arm to fit the post,fit the spindles and glue it up. At this point I drill my hole,install a screw and plug the hole.
In some thumb back windsors that I have,the back rail fits between the posts.They made a round tenon on the top edges of the rail and wedged it into a mortise on the post.These are very fragile and tend to break off so I don't like that kind of joint.
When repairing chairs with screwed arms I just remove the plug,unscrew the joint and when regluing put the same screw back in and replug the hole. Good as new.---Jack
Bruce, a MN Galoot
Thanks, Jack,
I thought I'd reinvent the wheel and try making a tenon on the end of the arm inserted into a matching mortise on the post. While a good idea, it's turning out to be a real bugger to get to fit properly. The rockers I've fixed before have had the arms screwed to the post so a bunch of other builders must think it's okay, too.
George Allchin in Lowell, Mich.
I agree the wood is too pretty to paint. Well done!!!
Work safe
George
I did that too in a chair I built this summer. It's a bear to get a nice fit.
I have a book"The Book of American Windsor Furniture" by John Kassay that is an excellent resource. It is full of measured drawings of old existing windsors. In drawings of that style arm ,the screw is shown. That pretty much convinced me it was not poor craftsmanship to use a screw.---Jack
Bruce, a MN Galoot
thanks for the reference. I'll get it from the library.
Thank you Tom
Thanks for the kind words.
Patrick Gibbons
How long did it take to build? Also, why did you use cherry for the arms? It's such a beautiful piece.
I'm not sure about times but I'm guessing close to 20 hours. The reason for the cherry is that I had a curved branch in my wood storage and the grain direction was perfect. ---Jack
