We value your privacy.
My shop has 4 fluorescent fixtures providing illumination more suitable to contemplation than work. I've tried various task lights. The clip ons fall off regularly. Incandescents and halogens burn my face or hand when I get too close. CFLs have insufficient light.
Chris Schwarz used and recommended the Lee Valley light with the Cree LED. It came today and gives preposterously good illumination. I expect to use it in a dog hole on my bench and also to walk it to the tablesaw and router table as needed. Yes, I'm a gadgeteer but this light is awesome.
Bruce....thanks for this review....I saw the C. Schwarz comments.....if it were powered by an electric cord, I'd personally like it more.....hate to keep feeding anything batteries.....but this product looks like it does what you want it to do.....which, in my case, will be to illuminate my saw work on dovetails (old eyes).
Totally agree with you and the Schwarz! I've had mine for a few weeks now. I've run through one set of three AA batteries. As they run down, they eventually go from brilliant mode to meditation mode, but continue to put out light. I already have lots of 3/4" dog holes and both vertical and horizontal ferrous surfaces in my shop, so the placement opportunities are legion. The absence of an electrical cord is very convenient, and it's brighter than the home made incendiary 50 watt halogen work light that I've preferred for several years.
I've only had one minor frustration with it. I moved my work-mutt from the non-climate controlled shop to a heated bedroom where I'm doing some trim carpentry, and the 1-7/8" thick maple top adjusted to the new environment, causing the dog holes to shrink very slightly across the grain. The stainless steel dog that attaches to the work light is made to very tight tolerances, and now doesn't drop into most of the dog holes in this bench. It's a trivial fix: I need to either redrill the dog holes, or replace the metal dog with a wooden dog, or turn the SS dog a smidgen smaller. The replacement would require a short section of 3/4" dowel, a FHWS, and maybe a little sand paper.
Highly recommended, and they would make any crafter on your Xmas list very happy. More info here:
It's the batteries that get to me, I do have rechargeable "D"'s and "C"'s but so far no "AA"'s, I just hate replaceing batteries.
I did buy the Ikea halogen light. Rigged it up on a piece of wood bolted to the cast tab meant for a worklight on a circa 1940's era Delta drill press. Zip-tied the light cord along the drill press cord, plugged it in, and that's it. Handy little thing and perfect for a drill press.
I got an Ikea halogen wall spotlight (which they don't offer anymore) and melded it with the arm of the $9 Ikea articulated reading lamp (imagine the Pixar mascot), and drilled a half inch hole in the end of a 3/4" dowel, so I could drop it into any convenient dog hole.
The corded models you've found are definitely viable alternatives, especially the less expensive ones, and especially when dedicated to a single stationary electrically powered machine.
We also have a few of the JANSJÖ lamps from IKEA around the house. I looked at adapting them to a magnetic base or to a dog, but then the L-V offer came out, so I discontinued that line of thought, which was getting a little complicated.
I had given away all my rechargeable AA batteries and their chargers a couple years ago, when I found I wasn't using them any more. I may have to look into getting a new AA charger, but I may find I've been spoiled by the LiIon batteries on some of my power tools.
In spite of it munching batteries, the L-V lamp is a lot more adaptable than the IKEA light, and also a lot brighter. I also find it a lot more convenient to move it from one stationary machine to another, e.g., band saw, drill press, lathe headstock or tailstock or bed, spindle sander, router table, etc., because it doesn't need a cord, and the electrical outlets nearest to some of my machines are very inconveniently located.
One thing that the L-V lamp is missing is a tripod mount, but that is also something that any of us could easily put together with a piece of steel angle, a hacksaw, a drill and a tap.
I can also attach it to the top or the side of my #6, #7 or #8, because there's no cord to get in the way, a distinct advantage when planing a very long board. It works great on my slicks, too.
I've been using the Harbor Freight freebies on a gooseneck that came via a vendor sample where I work. I use rechargeable batteries. I'm sure the LV with the CREE bulb is better, especially since you can adjust the beam. Might have to break down. Or, I might just make my own. I'm not a big fan of batteries either I must admit. 5V wall warts and resistors are cheap and easy to rig. No ideas for the focusing though.
Just an aside. I bought a 16 pack of AA Duracells at Walmart for ~$11. They are cheaper in greater quantities at Costco. Though I'm miserly with myself, I think the convenience of mobility is worth it.
I don't think I understand how Kickstarter works, but it kind of looks like crowd-sourced venture capital. Will he be selling kits or completed chargers, or plans?
For most CREE LED applications, it would be more convenient if it would hold 3 AAs or 3 AAAs at a time. Still, I would prefer juggling rechargeable batteries and a battery charger to dragging a power cord around, especially with the potential for dragging small parts and tools off my bench with the cord, and the potential for cutting the cord with sharp hand tools and power tools, and the inconvenient locations of some of my electrical outlets.
You got it. It actually seems to be a pretty successful concept. There is a kickstarter for a Willi Sundquist dvd, as summary of his carving life.
There are plans for a 4x charger, if he ever gets these 270, "hand made" chargers done, and moves on. He also plans to release all the documentation. That is the open source piece. So theoretically you could make your own. And decidedly, I imagine some chinese guys will be selling them on the bay.
One of the things he says, on the site you accessed, is that if a charger has a single light for a pair of cells, then it is a bad charger that will damage your cells. So all his cells are getting individual treatment. So if you bought a 4x or 2 2x, you should be able to charge 3.
It appears that his 2 cell charger will charge AA batteries only, and the new 4 cell charger (in development) will simultaneously charge two AA cells and two AAA cells.
The issue there is one of certification, and liabilty.... neither one is any fun.
Rechargeables are good option for shop use - less so for emergency use, as you can aways pop in a set of new batteries - evn when you're away from power (or it's out).
The issue there is one of certification, and liability.... neither one is any fun."
Thank you, Rob, for the enlightenment. Being a "dyed-in-wool" chord fanatic, I get pretty disgusted with all the horribly wasteful and long term danger of batteries; even rechargeables--with their associated obsolescence.
Not wishing to take away from consideration of the LV work light which has some features that I like better including a longer neck to support and place the light, I'll show my magnetic based Delta work light that I purchased a number of years ago. It seems like they were available back then for about $20+....and now, I believe they approach $40. It is a good light.....great magnet (you attach it to some metal object and its attached).....and a power cord.....but a relatively short neck.....
I can move it easily over to the bench for dovetail work.....
just thought I'd present another possibility to the conversation.....good light....not perfect.
I have one of those as well. I'm not sure it is labeled "Delta", but it's the same light. It came with some piece of machinery. I agree, the neck is too short and stiff, and it doesn't really meet my desires for maneuverability. Also, the switch is difficult to turn.
