A video Shop Tour
Michael Donaldson
Well, I'm set up for the Minnesota winter and had Emry, my 10-year-old daughter and fellow woodworker, help me film this quick shop tour. Enjoy.
A video Shop Tour
Michael Donaldson
I have a few criticisms
Patrick Gibbons
Your shop is sadly lacking on many fronts. It's too clean, too neat and organized, the lighting is much too good. Your tools have obviously been maintained by someone who cares and are of a high quality. How do you expect to bitch and moan with any authority? What excuse will you have for poor work? You've given yourself no room for failure. Is that really the example you want to set for your 10 year old? I bet your wife actually expects you to finish projects. You're a disgrace to the armchair woodworkers across America.
Re: A video Shop Tour
Jack Guzman from Maine
Michael,that is an extra special shop tour. Nice tool cabinet. I like the saw till idea.
My favorite part ,however,is Emry's tool area. The fact that she has her own tools and bench is awe inspiring. I noticed the row of sticky notes on her tool wall. Scheduled projects?Thanks for sharing.---Jack
William Duffield
I used to have a JET 1236 lathe just like yours. Before you build a cabinet to go between its legs, you should consider building a plywood or MDF box, attaching it securely between the legs, and filling it with sand (and sash weights or lead sinkers, or even rocks, if you have them). The sheet metal legs on that lathe don't do an excellent job of damping vibration, and you should get remarkably improved performance from the lathe by adding ballast. Consider a steep slope to the top so that shavings will fall out front onto the floor where they are easier to pick up. Also, seal the inside corners of the box with caulk (or whatever), otherwise, the sand will sift itself out and onto the floor. Massive, unconsolidated ballast works best, so even if you have lots of cast iron (or spent uranium) scraps laying around pack them in sand or shot. Attach the box both near the top and near the bottom of the legs, but make sure to leave yourself enough room under the bed to access the tool rest and tail stock hardware.
Perhaps I should have planned a little better
Michael Donaldson
She had the sticky notes up before the shop was even set up. She drew pictures of all the stuff she wants to make.
Excellent advice. I will take it.
That shop can't possibly be in Minnesota!
Bruce, a MN Galoot
You'd be wearing a parka to work in your unheated garage.
Maybe I missed it, but what do you use for heat?
I'm glad to see it's coming together for you, Mike. It's been long haul. You're a lucky man to have a daughter who likes to spend time with dad in the shop. What a treat!
Re: That shop can't possibly be in Minnesota!
Michael Donaldson
I have an electric heater on the wall behind the bandsaw. It has a thermostat that holds the shop at about 55 degrees. The shop is really well insulated on all sides, so it actually doesn't run too often. Even when it was 8 degrees outside, the shop held nicely at 55.
I love having Emry in the shop with me. Of my four girls she is the only one who has any interest in it. We went to Youngblood lumber together this past weekend and she helped me pick out some wood for Christmas presents, she is getting a pretty good eye for lumber. If you're ever over here in the cities, feel free to stop by.
Patrick Gibbons
You are lucky to have a daughter interested in shop work. My sons don't have much interest. You've got a great setup to share some quality time.
