New WoodChat!
Word of warning - The Art of Joinery 2nd edition
Zeb
Lost Art Press went with a glued binding on this book. I blind preordered it because their books have always been top notch sewn bindings but this one is cheap and shoddy so if you have't already ordered it be aware that it isn't up to their usual standards. According to email conversation with John Hoffman this was done in order to have the raggedy edges on the page. So it's form over function. Not something I expect from Lost Art Press.
Re: Word of warning - The Art of Joinery 2nd edition
Old Baleine
No one has touched this comment for two days, so I will.
Thanks to Zeb for pointing out this change in construction and for contacting John Hoffman for information. I haven't yet received my copy, so I am commenting on information I have taken from Zeb's comment and from the Lost Art Press website.
The Lost Art Press bookstore describes the new edition as "notched and casebound", and as having "rough exterior edges".
"Notched and casebound" means that the sheets on which the pages are printed are gathered into signatures, but rather than each signature being bound together by thread, the folded edge of each signature is notched by cutting out small squares along the folded edge. Think of a box joint. This is done mainly to increase the gluing surface of the edge. All of the signatures are then gathered together, forming the text block, and the notched edges of the text block are glued together before being bound into the case of the book (the "covers"), pretty much the same way their books have always been bound. The main difference is that the signatures are glued, not sewn.
While I agree that this is a departure for Lost Art Press from every other book they have published, it does not necessarily mean that it is "cheap and shoddy". Assuming LAP are as fastidious with their paper choices as they have always been, the critical component of this type of binding is, of course, the adhesive. If LAP or their binder specified a UV-stabilized polyurethane reactive adhesive for the binding, then this edition should open easily, rest open and flat, and last a long time.
Given the choice between a smythe-sewn binding with trimmed edges, and a glued binding with deckled edges, I prefer the smythe-sewn, but I am a stick-in-the-mud. I doubt that there is a significant cost difference between the smythe-sewn and a high quality notched and glued binding. The deckled edge, which LAP describes as "a feature like early books", is merely a design conceit. It is incongruous with several of the other editorial emendations of the new edition that are surely not a feature of books in Moxon's time, such as the inclusion of photographs. When paper was made by hand, the paper fibers were cast on a frame called a deckle. The edges of the sheet were irregular ("deckled") until trimmed. In modern papers, the deckled edge is an anachronism, sort of like stone quoins on the edges of modern buildings.
I think that what is most difficult for LAP is that this change was never mentioned in the roll-out to this new edition. It is a significant departure in construction from their previous publications, and Christopher Schwarz should have drawn attention to it, rather than waiting for his subscribers to discover it. However, depending on the binder's choice of adhesive and its proper application, it is unfair to characterise the binding as "cheap and shoddy".
I hope this helps address any concerns that might have been raised by Zeb's posting. For the record, other than being a customer, I have no connection to Lost Art Press.
Joe shelton
Quoins aren't anachronistic, they are merely expensive. Sort of like M&T joints where biscuits could have been used.
Old Joe
Wiley Horne--So. Calif.
Thank you for the explanation. Probably like many others here, I didn't comment on the OP because I have no knowledge of the subject (bookbinding). However, 'cheap and shoddy' are not words I would ever associate with Chris Schwarz or any of his undertakings.
On a separate but related subject, does anyone have comments on the $43 version of Roubo. And also, was Roubo's book solely about 'marquetry'? Or is the Lost Art Press version one piece of a larger original tome?
Wiley
Ladders ! ! ! I DON'T NEED NO STINKING LADDERS
Winton Applegate
Thank you all for the info and education (books and buildings).
As far as sewn verses glued I immediately thought of a prized and expensive (fifty dollars in the mid eighties and not all that many pages) bookI once bought and returned.
Reinhold Messner Everest Without Oxygen
God that was a cool book ! Excellent color photos and all.
Sewn binding. Nice looking book.
It fell apart before I was done reading it.
All I could figure was they sewed it too tight. Pages starting ripping loose where they were folded.
I hated to return it but sheeesh.
So I, for one, am willing to try a bit of glue but looser thread makes me feel more confident though may be unnecessary in fact.
PS: I had to post the link to this photo.
http://en.wikipedia.org/wiki/Reinhold_Messner
The boy is a lion among men. Look at that "mane" of hair. Upon reaching the first few glacial crevasses he yelled back to his team "Ladders ! ! ! I DON'T NEED NO STINKING LADDERS" and proceeded to jump the crevasses and ran away from them like the crazed wild man that he is. From then on he had to climb alone because no one could keep up with him, not even his hand picked number one climbing partner.
Dude !
PPS: I was wrong (it has been thirty years) this is the book I bought but he had just done Everest without oxygen.
http://www.amazon.com/Solo-Nanga-Parbat-Reinhold-Messner/dp/0195201965/ref=sr_1_16?s=books&ie=UTF8&qid=1384716957&sr=1-16&keywords=reinhold+messner
L'Art du Menuisier
Warren in Lancaster, PA
Wiley, the original work L'Art du Menuisier, Art of the Woodworker, had five parts:
1. Le Menuisier en Batiments, mouldings, doors, windows, architectural. (This section has two parts)
2. Le Menuisier des Jardins outdoor furniture
3. Le Menuisier Carossier carriage maker
4. Le Menuisier en Meubles furniture maker
5. Le Menuisier Ebeniste veneering and marquetry
Today menuisier is translated carpenter or joiner, but in Roubo's day it was a more general term for woodworker.
Re: L'Art du Menuisier
Thank you very much, Warren! This is the standard offering from the Lost Art Press,
http://www.lostartpress.com/product_p/bk-roubo-std.htm
And this is the deluxe version,
http://www.lostartpress.com/product_p/bk-roubo-deluxe2.htm
It appears to be part of L'Art du Menuisier, with additional volumes being prepared for later publication.
Wiley
