New WoodChat!
Paintable, gap-filling exterior adhesive
Last year, before my sweetie's surgery, I installed hand rails in the shower. It turned out the blocking we installed for this very purpose when we did the bathroom didn't extend as far as I thought it did, so I had to cut two holes (5" by 10" or thereabouts) in the painted wood siding to gain access to the back side of the tiled wall to install blocking.
I'm now getting around to installing dutchmen in those holes. I have cut pieces of siding stock with beveled edges and am tapering the holes in the siding to accept them. Perfection is not me, so there'll be some small (not greater than 1/16", I hope) gaps in the joints. I am looking at my choices for a gap-filling, waterproof, paintable adhesive available from my local hardware store. Epoxy appears to fit the bill, and the online references say it's paintable. Does anyone have experience confirming or refuting this claim, or a suggestion of some other adhesive that would be better?
Re: Paintable, gap-filling exterior adhesive
Jack Guzman from Maine
Bill,
I do repairs to old houses in Maine where the weather is alot less forgiving than yours and when I do exterior patching I use acrylic latex caulk with silicone or for bigger holes I'll mix up some minwax high performance wood filler.I believe it is epoxy base but I'm not sure. It is alot like bondo.---Jack
Mark Nowicki
I have used this to repair a cracked centerboard on my sailboat, and painted with Interlux Polyurethane. Three seasons later the paint is still there.
http://www.westsystem.com/ss/new-six10-epoxy-adhesive/
Mark
Clint Searl
Clint Searl
PL Polyurethane construction adhesive.
William Duffield
Another option is System Three SculpWood (a two part epoxy). It might have saved you a few steps in your patching and filling process, but you're done now, so this may be a higher performance product than you need.
http://www.woodcraft.com/Product/2003592/26196/System-Three-SculpWood-Putty-1-Qt.aspx
Mark's recommendation of West Six10 should also do the job admirably. I hadn't heard of it. Note however that all two part epoxy products with a mixing nozzle suffer from the disadvantage that the nozzles are not easily reusable, so they are a one application product, which offends some people's sense of frugality.
I'm sure there is a Bondo product that will work as well.
Be aware that any epoxy product being used in an exterior application is susceptible to UV degradation, so the System 3 and West System products should be painted for protection.
My experience with caulks, including acrylic latex and silicone, is that they are not sandable, and so you must smooth the surface with a solvent soaked cloth or paper towel before they cure.
roger lance
More info
John in NM
The mixing nozzle is called a static mixer and they are available for a few bucks each. Whether one can a mixer with the proper end to match the disposable tube is another question, the array of mixers available is bewildering. West System might provide some tech help on finding the proper one, worth sending an email at least.
I too would favor an epoxy product like Mark posted. Second choice would be a top dollar acrylic caulk as silicones are not paintable. I avoid cheap "painters caulk" at all costs, the stuff shrinks so badly in less than a year that it needs to be re-caulked. I've had better luck with the $5 per tube stuff.
Construction adhesive is less than useless IMHO. I have yet to see it last more than a few years in any application.
Thanks, all *LINK*
I wish I planned ahead better than I do; if I did, I could have tracked down some of the paintable epoxies folks recommended. But I don't, and the epoxy at my local hardware store isn't rated for painting.
I was reluctant to use Titebond, because, well, the gaps in the joints, while not huge, are there; and I didn't want to use caulk (DAP makes an acrylic latex caulk, Dynaflex 230, that I've used more than once as an adhesive caulk for pieces of exterior molding too small to nail; but caulk doesn't sand well). One of the customer service folks at DAP suggested vinyl spackle, of all things. I've used this a lot on outside holes, and it's worked well there. The rep said that, in the moderately tight joints I've got, this would work as an adhesive. So that's what I'm trying. The link below is to my post on Dennis Peacock's "what did you do this weekend" thread, with a picture of the work in progress.
I'll definitely keep all the good suggestions above in mind for future work, if I can just get around to planning a little better.
http://www.woodcentral.com/woodworking/forum/messages.pl/page/1/md/read/id/471539/sbj/i-m-fixing-a-hole-long-several-pics/
