Laminating Strips
James Blandford-Baker
I'm making some slats for the backs of a set of dining chairs. They are bent slats so I'm laminating them from 5 pieces of 3mm oak strips (17mm wide). The process involves producing one planed face, cutting the 3mm strip on the bandsaw and then replaning and cutting the next strip. I would really like to be able to get a nice flat surface on the bandsawn side so that all the strips glue together with an almost invisible line (I've been numbering the strips as they are produced to make sure they go back in the same order as they were cut).
I discussed a similar process with James Ryan from the Edward Barnsley workshop recently. He explained that they smooth the cut face on a thickness sanding machine and get excellent results. I don't have a thickness sanding machine!! Does anyone have a good process, or a jig that would be possible to produce in a home workshop to do this? It needs to be controllable. I've tried scraping (very difficult with the 3mm thin strips) and hand sanding (not controllable enough).
Any ideas would be most welcome!
Thanks
James
) works well. If you make a mistake and feed the strips in the wrong direction, you probably wont make the same mistake twice. If, after glue-up, you need to work the final surfaces for fairness and thickness, the sanding drum works for those purposes, as well, but for final thicknessing, you need to replace the flat fence with a single point fence like you would use on your bandsaw for resawing.
