New WoodChat!
Dividers *LINK*
Dividers *LINK*
Dividers *LINK*
Patrick Gibbons
I'm wanting to buy some dividers to use on wood, not paper. I like those that C. S. Osborne make and was wondering what size was best or even if it was an issue.
http://www.csosborne.com/dividers_1.htm
Re: Dividers *LINK*
Re: Dividers
Rick W
I have the 8"Osborne dividers with the replaceable point like the ones on the right.They have worked well for me for several years. I mostly use them with a pencil.
They were expensive, about $60.00 new. They are very well made, and should last indefinitely.
If I were you, I'd look for a similar pair of dividers made by Starrett or other quality makers on eBay or elsewhere. You'll pay a LOT less, and get a tool of similar quality.
Rick W
Re: Dividers *LINK*
Re: Dividers
The size, of course, depends on the scale of your work. If you're doing a lot of those cabinets with the big shell carving at the top, larger dividers might be nice. But for general shop use, I'm with Rick on both counts: 8" is about right, and get the type on which you can use a pencil or the steel point. I have a very similar pair, found at a yard sale, that I use regularly...in fact, they're hiding from me right now (I just looked for them to measure them) from use on the project in progress.
For larger circles, you can always make/use trammel points, which can be as simple as a stick with a nail for your pivot point and a pencil shoved through a hole drilled in the stick, or even taped to the stick.
Re: Dividers *LINK*
Of course, if you really want to treat yourself *LINK*
I have a set, inherited from my uncle, of the Starrett #85 dividers, which have replaceable legs for dividers, pencil dividers, and inside and outsider calipers (link below). Starrett even used to offer a leg that accepted little half-domes in several sizes, so you could scribe a circle around an existing hole of up to about 3/4".
These will never fail you. You may, however, need to know CPR for wallets before opening the link; the price is kind of stressful on most wallets.
http://www.starrett.com/metrology/product-detail/Precision-Measuring-Tools/Precision-Hand-Tools/Calipers,-Dividers-and-Tram/Calipers-and-Dividers/85F
Re: Dividers *LINK*
Re: Of course, if you really want to treat yoursel
Tony Wilkins
I really like mine made by Peter Ross. You can just seeing them being used in 200 years.
Re: Dividers *LINK*
Patrick Gibbons
Hardcore, Bill. I'm drooling.
Re: Dividers *LINK*
Thanks for the help
Patrick Gibbons
Pulled the trigger on the 8" with leg or pencil. $45.45 at Epstein's. $66 to over &100 everywhere else.
Re: Dividers *LINK*
Hell, I can make you a pair. They may not last 200 years, but they will look like they have had 200 years of use :)
I have two sets of dividers, both Starrets. One lot are 3" and the other 6". The smaller set are ideal for dovetailing. I collected mine via eBay but Lie-Nielsen sell them: http://www.lie-nielsen.com/catalog.php?sku=Dividers
Re: Dividers *LINK*
Jack Guzman from Maine
I have a set that are completely blacksmith made. 12" I believe. A real beautiful thing if you can appreciate that sort of thing.---Jack
Re: Dividers *LINK*
Re: I have both kinds.....
George Allchin in Lowell, Mich.
but use the extension version more because of it's flexibility:
put in a pencil
make up "Z" shaped extensions for larger arcs
or whatever other uses you come up with
Work safe,
George
Re: Dividers *LINK*
Another option
If it is wide circles that one needs to draw, use a trammel. This is easy to rig up temporary, or buy one off several vendors options.
I have a vintage set. This offers the choice of point or pencil ...
Re: Dividers *LINK*
Nice kit, Derek
Re: Dividers *LINK*
Re: Dividers follow up
Patrick Gibbons
Received the dividers from Epstein's. They are the 8" extension dividers and Osborne's description states they are highly polished. Mine were not what I would call highly polished. This is not really a criticism, just an observation. They are stoutly made. There is no wobble or deflection, the points line up precisely and are quite sharp. The tightening screw for the extension leg is frozen tight but I think some WD40 will loosen it up. The spring is very stiff which facilitates fine adjustment. I can't imagine ever wearing the spring out. The wing came with round indentations from the tightening screw. I called Osborne to ask them if this was normal. The man said he had observed this also and wanted to test if coating the end of the screw would fix this. I'm not sure what exactly he had in mind. Two days later he called me back to let me know that the screw held the setting best the way it was originally. He said the indentations shouldn't effect the operation of the dividers but if it was a problem he would be happy to send me a replacement wing. He also observed that the screw held with light pressure. It wasn't necessary to crank down on it. I'll report back in a month or so.
