New WoodChat!
OT - moisture content in wood floor
Our Queen Anne cottage, like many around here, has 1x4 tongue-and-groove Douglas fir flooring as its combined subfloor/finish floor. Doug fir is a splintery wood, so we explored putting in a hardwood floor. The contractor came out today and recommended against it, because the floor showed 12-13% moisture, and the hardwood flooring would probably come at 6-8%, and then warp when the moisture equalized between the two materials.
Testing elsewhere in the house got variable readings, down to 10% in spots.
We have no air conditioning (don't need it), nor humidity control, and heat only when temperatures drop in the Fall. For about half the year, we live with windows open much of the time, closing them if the temperature's going to go over 75 degrees.
Is this moisture range a matter of concern, or just an indication that we're just living in sync with the outside world?
Re: OT - moisture content in wood floor
Dale Lenz
Dale Lenz
12~13% MC of wood is typical for many areas of outdoor conditions. Would think you could sticker wood flooring material for say 6 weeks and let it condition to the environment it will "live" in. During the winter months, when the cottage is heated, bet the MC drops to near 8%?
Patrick Gibbons
Just curious how the Doug fir looks and how well it held up over the years?
No advice, but
Bruce, a MN Galoot
I'd sure hate to live in sync with our outside world.
Re: OT - moisture content in wood floor *LINK*
Patrick Gibbons
Here in Houston engineered hardwood flooring is popular to combat the humidity problem. Also mesquite solid wood flooring is stable enough to be used in a bathroom without any consequences. Mesquite flooring is expensive in Texas. I can only imagine what it might set you back in California. However, it's cost plus shipping. Here's a link I found about engineered flooring.
http://shawfloors.com/tips-trends/natural-hardwood/hardwood-solid-engineered
Jack Guzman from Maine
Bill,I'm no expert but that don't make alot of sense to me. I would think that if you brought the new flooring into the house to acclimate it would be equal in moisture content to your existing flooring and then installation would be no issue.Place rosin paper or something similar between the layers and leave space around the perimeter for expansion. ---Jack
Patrick Gibbons
Here's some info on mesquite stability.
http://www.mesquitefloors.com/hardness-and-stability
Agree
Frank D. in Montreal
Up here in Montreal, with sub-zero winters and hot, humid summers, solid wood floors are very common. We use run-of-the mill native species (maple, birch, oak) and I've never heard once of anyone having problems due to the wild seasonal humidity swings we have (which is why they've been used for hundreds of years) when the floor has been installed correctly. The only potential problem that I can think of is if your floor is right over a dirt crawlspace, so during prolonged periods of rain (I'm thinking weeks on end), water could wick through the soil from outside and off-gas into the house from below. But this wouldn't be caused by ambient humidity. Even then, a layer of tar paper on the sub-floor would pretty much protect from that.
Michael Donaldson
Amen to that, Bruce
