Small router plane......
roger lance
Awhile ago, Derek Cohen posted about a small wooden router plane that he had made. I had an idea then of how I might make a small plane that would also use the router blades that come with the large LV router. Surprisingly, LV has failed to make a small router that can use these blades.....instead they have decided to use a round shafted blade in their small router which is offered in only one size.
So the goal was a small wooden router that could use all of the router blades made by LV for their large router and also have a way of securing the blades in the router that had more bearing than that shown by Derek in his design....
This is my prototype with a template of Derek's plane body.....
And a look at how pinned that blade shaft is to the body of the plane.....it is very secure.....there will be no rotating of the blade shaft....
The blade can also be used out the back for those rare occasions when that might be desired.....
Now, if I could just figure out a way to make a better shooting board plane than LV or LN.....
