We value your privacy.
In Michigan like much of the country, we are under the heat bubble and have some seriously high humidity as well....and things are swelling up in the woodshop. My major means of fighting these conditions is a dehumidifier.....running 24/7 with an attached drain hose running to a floor drain. Don't want rust on my beloved tools. The local weather gurus say relief is 2 days away.....
Ditto here. I rarely run the dehumidifier, but when the dewpoint gets into the upper 60s (and it's now in the mid 70s, almost unheard of here), my garage shop goes to 70% humidity or so and things rust. And when the shop is 80 degrees and 75 degree dewpoint, it is to the point that it is almost difficult just to walk around in it.
I have neither air conditioner nor dehumidifier in the shop and just spent the last four hours in the shop. The temp in the shop is 93, with a dew point of 71. Relief is supposed to come tomorrow, which is when I will start to stain the table. It just wouldn't do to try to stain with sweat dripping on everything.
I run warm air from the attic by fan to the shop. The shop is normally cold due to all the concrete and machines. Particularly metal working machines make the place like a fridge. So the dew point is a threat. But moving in the hot air is a cheap solution. Basement shops I have had, and never want one again.
Mine has been running since May. I keep the ac on but turned up real high. The dehumidifier takes the edge off. I've wondered if just running the ac lower would use less or equivalent energy? My dehumidifier control has died twice (over 14 years), but the unit runs fine. So, I am in the process of making my own. You can buy a plug in for $60 on Amazon, but I like tinkering with electronics. I'm using an Arduino with a temp/humidity sensor and a PowerSwitchTail (relay). It works good. I'm going to package it all up into a nice box this weekend (then the unit will quit! Ha!).
It's not the humidity, per se, that causes the rust. What you need to watch is the dew point, which is the temperature at which the water in the air condenses. The higher the humidity, the higher the dew point. If the temperature falls below the dew point, then your tools get wet, and rusting starts. What you need to know is the current temperature, the current humidity, and how cold it's going to get tonight. Of course, if it is currently foggy, then you are already below the dew point outside. If a cold front is approaching, then the air behind the front is usually dryer than the air that is going to be displaced, and the chance of condensation in the shop decreases, with the expected decrease in the dew point. If a warm front is approaching, then the air behind the front is usually wetter than the air that is being displaced, and since your machinery is relatively cold, the chance of condensation increases, because it's the dew point at the surface of the iron and steel that causes condensation. Note that a dehumidifier both reduces the humidity and raises the temperature, moving the dew point further from your current conditions. An air conditioner, OTOH, both reduces the humidity and reduces the temperature. This is still advantageous, because further cooling of the air is much more difficult. Also, you are less likely to drip sweat on the machinery. But turning off the AC and opening the doors and windows allows humid air to enter the shop and condense on cold tools.
Blowing the sawdust off at the end of the day, wiping tools and machinery down with an oil-impregnated cloth, storinging your tools in a closed, well-fitted wooden case or toolbox, and covering cast iron surfaces with tarps at the end of the day all help to mitigate corrosion. Also, it's a good idea to keep the wrens out of the shop, because bird poop is even more corrosive than sweat and soggy sawdust.
Joe....running a dehumidifier and/or air conditioner will certainly make for higher electric bills.....but, sometimes its easier to pay a bill than remove rust....I'm trying to establish a steady state of about 55% RH.....since all metals are not the same, some tools will rust before others.....and when we add cast iron to the mix, we have a lot of variation to the quality of CI and tendency to rust (I had a new CI tool table from Delta that was rusting under the cosmoline shipping coating.....Delta replaced that table).....I'm interested to hear from others regarding your question.
