Veneer question
Moses Yoder
There is not much hand tool content here but I think maybe a hand tool is the answer to my problem. I don't know a lot about veneering but the job I started at the end of February requires immense amounts of veneering. I am building these rangehoods.
The bottom is a front and two sides of mitered plywood with molding top and bottom. This is assembled separate from the top and when the top and bottom are completely assembled then the bottom is attached to the top. The top is made on a table with curved grooves to slide the sides into. A rib is put in the back and a gusset at the front, then a bulkhead is installed about 12" from the top and the front is attached. The sides and front are 3/8" bending ply. After fairing the carcase contact cement is sprayed on the two sides and the veneer for the sides. The two pieces of veneer are stuck to the sides with a veneer hammer, trimmed flush at the back and about 3/32" overhang on the front then sanded flush with a Dynabrade random orbit sander. The sides are easy and do not create a challenges. The front is what is a problem. The fronts are stuck on and trimmed close to the sides then sanded flush. I use 150 grit to sand the edges of the front nd then finish with 220 grit. The problem occurs when I sand a little to hard to remove the reulting glue line at the edge and sand through the veneer on the side at the front edge. Sanding through is a real PITA and requires stripping all the veneer off with laquer thinner and starting over. Hard Maple veneer, Oak veneer, and rotary cut Maple veneer that we use for paint grade is thicker and is fairly easy to sand with no sand through. Cherry and Alder are extremely difficult due to how thin they are. I would say on cherry every sixth carcase is ruined, on alder every fourth. Sometimes it is just a little and we send it anyway but I don't feel good about it. We mask the front edge of the sides with 3" masking tape but due to the curve it can't be masked perfectly so we don't waste our time trying. This results in a glue line at the front edge from the glue overspray that has to be sanded off. One thing to keep in mind is the speed at which these must be made; I am not a fast worker and build two complete units in about 9 hours. Of course my parts are already made, I just pull them off the shelf and mark them out of inventory. I thought maybe the collective wisdom here could come up with a solution, maybe a hand tool of some sort to trim the curved edge.
