New WoodChat!
Name stamp
Name stamp
Name stamp
I am after a name stamp for my furniture and tools, and need a recommendation. Or advice.
As I discovered in my research, there are two types of stamps. The "Makers Stamp" creates the name in relief, while the "Owners Stamp" recesses the name. So about a month ago I received a Makers Stamp from a well-known stamp maker. This had letters 1/8" high (I wanted something small that would not dominate), just my name.
As much as I tried, I could not get it to make an impression in either end grain or face grain. I gave the stamp as solid a wack as I could with a small hammer (actually a gennou). Any harder and I feared doing the wood damage. As you know, our local woods are hard.
I know the stamp works as it came with an example in what looked like white oak end grain.
So I contacted the (US) company asking for the secret. they replied ..
Yes, the end grain is the only way to get
an impression that does not crush the wood.
Your piece needs to be on a very dense solid surface
such as a cement floor, or anvil or other.
And you will need a heavy hammer like a 3lb sledge.
Depending on the size of the stamp.
Face grain can actually be done by branding.
The stamp can be heated about to a blue color, and
then held on the wood. It actually can look quite
nice making a black background with light lettering.
Work with some practice impressions in endgrain until
it works for you.
A 3 lb sledge hammer! Are they nuts! And if I wanted a branding iron, I would have sought one out at the outset. I was not pleased.
Anyone have the same experience and have a solution, or are my expectations simplistic? I think I may have to settle for an owners stamp as this has less surface area to imprint.
Re: Name stamp
You ever watch the end of Dragnet?.....
roger lance
Derek.....as no one has responded as yet, I wondered if you had ever seen a TV police show called Dragnet with Jack Webb? It was made in the 50's/60's and at the end of an episode after they sent the bad guy off to the penitentiary....this sweaty hand would appear holding about a 3 pound sledge that was struck on a stamp that read, "Mark VII Limited". What they are asking you to do does seem a little heavy handed.
Re: Name stamp
Re: try clamping
Edward in Vancouver
My stamp came with instructions to use a 2 lb sledge. Of course, I use a vice-grip to hold the stamp steady while I swing away, instructions never said anything about that......
I remember reading a blog maybe a year ago about a guy with the same situation. What he did was make a little wood "open ended box" for the stamp. This box was pressed against the item to be stamped with a heavy duty clamp. No violent movements, just steady increasing pressure. Might be worth the time to make something similar and fool around with it.....
Re: Name stamp
Stephen Shepherd
Try getting the wood wet
Re: Name stamp
Another suggestion.....
roger lance
In addition to Stephen's wetting the wood, I'd identify just where I was going to place my stamp markers mark and I'd make the mark on the piece in question before assembly. Much easier to do, less stress on the finished piece, and if you make a mistake....make a new element.
Re: Name stamp
Jack Guzman from Maine
That's just plain silly
You spend hours carefully crafting something.Use very sharp tools,light mallet taps,carefully finish your project and they expect you to sign it with a 3lb sledge?I could see maybe signing a 2" thick slab table top that way but that's about all.
What you need is a sharper stamp that makes an imprint with a light touch.---Jack
Re: Name stamp
Re: That's just plain silly
Matt Bickford
I sign all of my work with that type of stamp (likely the same manufacturer) and a 3 lb sledge. The thickest portion of the largest plane body that I sign is 1". The thinnest is 3/8. It works just fine.
A sharper stamp isn't necessary, practice is.
Re: Name stamp
Given the surface area...
John in NM
This does not seem surprising to me at all. A heavier hammer will keep you from having to wale on it - and that will help avoid glancing blows and other mistakes. Chances are the stamp maker knows what they are talking about.
I often stamp stuff I make with 1/4" letter stamps and use a 1# ball peen with a moderate blow. Heavier than a tap, but nothing like driving a nail.
I'm a bit confused though, it sounds as if crushing wood fibers is not what you expect from a stamp? Even raised letter stamps crush the wood, it just takes less force to do so. I'd never really thought about a raised field stamp before, but it does make perfect sense that it would be most useful on endgrain, and that is where I've seen them used. Before someone jumps all over that, I have not made an extensive study of stamp locations.
I'd go with the heavy hammer, light blow, and practice.
Re: Name stamp
Re: Given the surface area...
I agree John. After seeing Matt's efforts, and method, I will give it another go.
Oh, I expect to crush wood fibres - I just did not think it would be this difficult. And then I was concerned strong arm methods would destroy all the nice work :O
Re: Name stamp
Yeah, about like that....
John in NM
Hard, but not nail driving. I suspect a lot of practice is required for those big stamps.
I read a comment that mentioned a press. A friend of mine makes small presses for jewelers, when he first started he was using an air over hydraulic set up. With low air pressure the ram really snuck up on the desired press pressure. Pretty pricey set up though, I doubt anyone would go to those lengths in lieu of a bit of practice with a small sledge :D
Re: Name stamp
The video was very enlightening...
John in NM
I've never used that type of stamp... I would have probably started with a smaller hammer and a lighter whack and been surprised what it took to do the job :D
Makes me wonder what kind of music I need for plastering a wall :D :D :D
That's what I should be doing today, instead of drinking coffee and hanging around on the web
Re: Name stamp
Re: "Strike it"
Tom
You really have to whack it. I have been buying various stamps for leatherwork, and in some cases a 3 ton press doesn't make them work. I made a die that was designed to cut out a 1" finger hole, so I took a band for a turning tool, cleaned up the diameter in the lathe, and bevelled the interior. there was a visible line to the edge, but I figured that would make it more durable for when it contacted the anvil, and I then tried to strike it.. No way it would go through the leather with my 250 pounds on the 3 foot lever of my turret press. So I sharpened it a little, and it cuts fine now. But imagine now you are trying to impress some hard wood with an equal surface area of relief stamping. That is going to take some doing What is the surface area of 3 inches of edge that is about 10 thou, not much compared to a makers stamp, and leather is easy to cut or stamp compared to wood.
Re: Name stamp
Whats wrong with lasers
mark hennebury
Laser engraving is great: very fine crisp detail, You can make or can modify your design anytime, its cheap, you can do large of small areas, even really small lettering and logos. Any local engraving, trophy or gift store will do it.
I used to get lots of laser engraving done when i was making gift items, like the business card holders below.
Best of all ...you don't have to belt you fine wooden treasure with a 3LB maul!
Re: Name stamp
Crushing fibers
Patrick Gibbons
I have two old sets, one letters and the other numbers. The craftsman who owned the numbers before I did, relieved the ground around each number. The impression in the wood is much crisper than the unrelieved letters.
