Update on Kist.
Here is an update on the kist, or blanket chest.
One of the issues that I faced when building from Curly (or Fiddleback) Marri was that it is far from being clear wood. It is filled with veins where resin has dried and fallen out. These need to be filled with black-tinted epoxy. However, too many of these would make the wood look like a Dalmatian.
Here is an example. This goes all the way through the 3/4" board ...
I had started with 10" wide boards. By the time I had cut around these, some were only 4" wide. It was going to be necessary to join boards to reach the 20" panel width I required.
Joining boards is complex enough when there is figure to match, but here this was further complicated by the fiddleback in the boards - having this run in any direction but with each other would made the combination untidy and accentuate the fact that several boards were used. I think most of us try to make joined boards look like a single, wide board.
I am curious what others do to match boards - go through lots of stock to find the widest, best matches? Tint/stain boards to hide colour changes? What do you do when there is just enough for the piece one is building?
I really only had just enough for four sides and the lid, and spent quite a bit of time moving around boards to create an integrated, interesting combination. For three panels - the front and the two sides - I managed to use three boards each. The rear panel, which will go against a wall, has four boards. I think it epitomises what I wanted to avoid (but just could not with the limited stock available - and, yes, I did try and obtain more).
To obtain the best match, the grain of each board does not all flow in the same direction. This should make planing a little more complex, however the grain switches direction all the time, so who is to say in which direction the grain actually lay.
There was a lot more scraping done than just planing.
Yesterday I glued the panels together along with the base, which floats in a dado.
Today I planed down the sides.
I do love it when the first plane strokes uncover the details that lie below ...
All sides were given a final scraping.
Then came a couple of coats of Danish Oil - the fiddleback will respond best to oil.
First, the worst - the rear panel - fortunately it will be hidden! ...
Here is the front panel ...
From one side ...
... and the other ...
Unfortunately the fiddleback figure was not clear in some of these picture. It is really striking ...
That gets me about one third of the way through this project. The remainder promises to be more fun.
