Define "need".
I do not actually "need" a lot of things in the shop: more than one handplane, more than a half dozen assorted chisels, one backsaw could do dovetails and tenons, a tablesaw, router, random orbital sander ....
I don't need a shooting plane. However I have 3 dedicated ones (Stanley #51 - now retired; LN #51, and a shopmade Strike Block Plane)
I find more use for a shooting board than a ROS. It is an extremely useful tool that also gratifies ... nothing like sneaking up on that "perfect" fit. It is great for sizing and squaring drawer fronts and stretchers before dovetailing or sawing tenons. It is, clearly, a dedicated tool - but so is a ROS, and mine (a Festool I purchased 15 years ago) only gets pulled out about two or three times a year. Perhaps I should get rid of this quality tool for a multi-use sanding block?
I played with the plastic model of the forthcoming LV shooting plane in January when visiting the factory. It clearly will set the bench mark for shooting planes. Indeed, I can see an immediate advantage over my (common angle but skew-bladed) #51 and even my strike block plane (with a low cutting angle): the LV is BU and offers both a low cutting angle (for end grain) and, with a blade swap, a high cutting angle (which will be valuable for side grain). This does not say that it is a "need", but it does say that it meets a need for some and does so very well.
Incidentally, LN also has a leftie in the pipeline, but there has not been (as far as I know) any word when it will be launched.
