Slipping/spinning saw nut help
Dave (Arlington, VA)
Hi All -
I picked up a "Warranted Superior" George Bishop saw over the weekend. Nothing really special. I picked it up because it is a 5 1/2 PPI and while I have a couple of other large toothed saws, I don't find many hereabouts. So, when/if I see one I pick it up. I was thinking of converting it and filing it crosscut since my other large toothed saws are filed rip.
I wanted to remove the handle and clean up the blade. I has simple brass single slot screw nuts. Four of the five will come off just fine, but one simply spins in place when I try to unscrew it.
I have tried a couple of things to get it loose:
1. I placed a piece of sandpaper under the unslotted side of the screw nut on my bench top and tried to unscrew it using as much pressure as I could muster on the slotted side - hoping the friction from the sandpaper would hold it in place as I unscrewed it, and
2. I used hot melt glue on the non-slotted side and glued on a small wooden block to the unslotted nut. I then drilled a hole in another block of wood (so I could access the slotted side of the nut) and clamped the two blocks of wood together as tight as I could (on both sides of the saw handle). Then I tried to unscrew it....but, again, no luck. The combined glue and pressure didn't work and the screw spun in place.
I've assumed because of the design of screw nuts that penetrating oil is not likely to work.
The handle is in great shape so I am unexcited about doing anything that could damage the handle. I am also unexcited about cutting a slot in the unslotted side of the nut...which is the only other option that comes to mind.
So, does anyone have any "old tricks" they'd be willing to share? I've run out of my own.
Dave
