New WoodChat!
acid finish on steel
Jerry Gibbs
Robin Corell posted a picture of a bar stool. Legs were steel with an acid finish. I don't have a clue about an acid finish or where to ask to have it done. Can anybody get me started? I have a walnut slab I want to make into a simple desk with a steel frame base. Jerry
Re: acid finish on steel
David Barnett
(Message Deleted by Poster)
Yikes, nasty stuff
Bill Tindall, E.TN.
Most MSDA sheets I look at appear more alarming than the ingredients warrant. This one is an exception; it is a bad as it says it is. Selenium compounds are exceptionally toxic. While I would have no fear of brief exposure to phosphoric acid Fluoroboric acid can cause nasty and long lasting burns that require specialized treatment. I have no idea how the leftovers could be legally disposed of. I need to supplement my sheep with selenium so it is not an issue when highly diluted. Ditto for the other stuff, should that suggest a means of disposal.
Gloves can be way worse than not using them if they leak with stuff like this. This would be a mixture that I would double glove, nitrile with the heavy "kitchen" gloves over the nitrile.
David Barnett
Hydrofluoric gets my vote
mark hennebury
Hydrofluoric acid is the nastiest stuff that i have used.
Reading the MSDA sheet is scary as hell, but using it no fun either. I used some years ago for glass etching...once. Sandblasting is a lot more comfortable way.
However I currently do have a dilute Hydrofluoric in the shop for glass clearing ( removing mineral deposits) Splash shield and Double gloves when i use it, (always worried about a leak in the glove)
Stephen Shepherd
If you have the time...
Stephen Shepherd
wash the steel/iron with soap and water and let it dry. Then put it in a bucket of urine, checking every week to see the progress. Safe, renewable and easily disposed of properly.
Stephen
Re:  I learned everything...
TomD
I need to know about hydrofluoric acid in breaking bad.
David Barnett
HF a poor choice for dissolving corpses
Bill Tindall, E.TN.
Sulfuric acid would indeed dissolve a corpse. HF would not and it would be greatly more expensive and harder to get.
The reason hydrofluoric acid is so bad has to do with bones. HF easily passes the skin barrier, penetrates flesh and eventually finds bone that it reacts with to make calcium fluoride. I don't know why this is bad but it is. I am told the pain is unbearable and the sores slow to heal. The antidote is a magnesium compound(epson salts?)which reacts with HF to make an insoluble product
A good friend ran the lab at Oak Ridge that recovered the U235 from the separators. HF was used to dissolve the uranium. The women that worked in the lab occasionally suffered nasty burns. The first material recovered was put in a vial and sent to the president for show and tell. When it was returned my friend kept it in the lab safe. The scientists were unsure of precisely how much uranium was needed for a critical mass. To be sure there was enough even this first vial of material was sent off to Los Alamos to be packaged and given to the Japanese (story from Kent Brannock).
there is just no place like woodcentral
And now for something completely different
Patrick Gibbons
Their bluing is great for aging nails and screws. It can be applied after the metal is in the wood and won't discolor it. So far I haven't been poisoned yet, but I have had cancer.
Re: HF a poor choice for dissolving corpses
TomD
The generosity that surpasseth understanding, though I think they got the message.
Re: Yikes, nasty stuff
Robin Corell in Atascadero CA
It is impossible to tell what is in any product by looking at the MSDS. It is common for companies to not list the true ingrediants or proportions on an MSDS this is perfectly legal as long as they list all the actuall ingrediants and an amount equal to or greater than the amount for each ingrediant. this is done to acount for manufacturning variables along with possible substitutions. the true reason is to keep propritary recipes secret
For instance on the MSDS for aluma black it lists a bunch of ingrediants along with water and the % by weight for each ingrediant. for Aluma black the acids and sulfates all add up to 18% by weight and the water is 94% by weight. even using the new math this cant be correct. so what gives? Birchwood Cassy dosent want to give away the recipe for their product so they list all the ingrediants and maybe an extra one or two and say that the prodcut contains no more than what ever thay want so long as it is more than what is actially in the product.
I'm not saying to ignore what is in a MSDS. I think we have to asume that any product could contain the amount of any chemical listed on it and to take any precautons nessesary to safely protect ourselves, but also know that the MSDS does not acurately reflect what is in any product.
Robin
topcoat?
Jerry Gibbs
Does the steel need a topcoat after the acid treatment?
Re: topcoat?
Robin Corell in Atascadero,CA
Yes, the steel will neesd a sealer. It will look very blotchy and have some light surface rust. I use a small propane torch to heat up the metal to drive off the moisture that is in the pores of the metal and while it is still warm I apply some paste wax. I use Tre wax, but johnsons is just as good. The wax will darken the color and even put the tones a bit if it is solid while the metal is warm enough to melt the wax.
Robin
