New WoodChat!
Preparing for the Perth LN Tool Event
Next weekend in Perth is the LN Tool Event. This is the third or fourth year it has been held. Each year I have been invited to provide a weekend of demonstrations. I have tried to vary these. This year I suggested plane making and, before I could change my mind, this appeared on the adverts. It dawned on me shortly after this that I should have suggested something simpler. :O
In for a penny, in for a pound ... I spend the past three weekends building planes to take with me as examples. I have a number of planes I have built over the years that I could take along as examples - a recent bridle plough and a jointer, two dovetail planes (one male and one female) ... the list is quite long. However I thought I needed something fresh.
I also realised that the type of planes I could build in front of an audience (whom I am sure will get bored and move on) would be limited to those I could chop out in front of them. Some thing like a coffin smoother. So I have planned for this. The problem with these planes is that they are not for absolute beginners. The easiest plane to build is a laminated body, notably the Krenov plane (with a correctly shaped cross piece, which is the most important part of the design). However these are machine-made planes, which I cannot do at the Tool Event. To demonstrate these planes, then, I have made up a model that can be broken down, and several examples of a Krenov.
The third type of plane I have to show is a router plane. These are easy to build with a drill press. I shall give anyone interested a plan to use at home, plus demonstrate its use. I've made up a few for sale as well.
Here is a my bench as I tidied up this evening ...
I really like these router planes. They are what I would call a "Medium" - smaller than a large and larger than a small. Really an excellent size, nimble and very precise. Think of them as a woodie - they do not need an fine adjuster as they are adjusted with a light tap from a mallet. The planes use the Veritas irons, so there is a range from 1/8' through to 1/2" available (there's a 1/4" and 1/2" with each one on sale). The blade holder uses a wavy washer (like the Veritas), which means that you can loosen the wing nut and the blade will not drop out. There is a depth stop (which I consider a vital piece of equipment with a router plane).
Krenov smoother in West Australian She-oak. This is 7" long, with a 1 1/2" Hock blade/chipbreaker at 55 degrees.
Three Krenov block planes. 5 1/4" long, with two in Jarrah and a third in Tuart (a very hard Aussie wood). 1 1/4" Mujingfang blades (from Lee Valley), bedded at 40 degrees.
I am so impressed with these Krenov planes. I have an original plane from Jim Krenov, which I use on occasions, but otherwise have never had much interest in building these planes. They are soooo sweet!
I built this coffin smoother today. The body is my favourite Tasmanian Blackwood (similar to Koa). The 1 3/4" iron is a (NOS) J.Herring & Sons, which is laminated and tapered. The body is 6 3/4" long.
You have seen the 15" Jarrah Strike Block Plane already ...
Here is the Krenov that can be pulled apart. Along side it is an example of the router plane post drilling and pre sawing ...
Lastly, there are blanks in various stages for building the smoothers ..
All suggestions welcomed.
Re: Preparing for the Perth LN Tool Event
Jay St. Peter
All the planes look great!
I particularly like the router plane since I've been wanting one anyway. I might just have to build one of those. Looks like a quick fun project.
Your work is alway very impressive and admired.
Ron Harper
With what I know about your schedule, the amount of work that you produce is astounding. Even more o, when the quality is factored in. You set the bar very high Sir
The router planes get a slight face lift.
Hi Jay
The new knurled knobs ("brass coupling knobs", from on ebay) arrived today. I am so pleased with them! I think that they really lift the router plane's appearance ..
There's a wavy washer in front of the knob. It act as a spring and allows the knob to be loosened without losing all tension. So, when loosening off tension on the blade to move it, the blade remains under some tension, but can still be slid up or down.
I plan to post a pictorial shortly, one you can follow and build your own.
Re: The router planes get a slight face lift.
Jay St. Peter
Awesome, much appreciated. I've never used a router plane before, but from watching what others use them for this looks like it will do a great job for minimal cost. I'm pretty excited to build one.
Question about your router
Patrick Gibbons
You're using a classic design, for the most part, with smart improvements. To use this design the router is held closer to the blade edge than a metal router which has higher handles. I know you have used both types of routers and wonder what your observations are on differences, if any, in how the two feel in use.
Re: Question about your router
Good observations, Patrick.
I have mentioned that I consider this router plane to be a medium size. A Stanley #71 is 7 1/2" wide and this woodie router plane is 6 1/4" wide.
What is strikingly different is the feel and the feedback. The woodie is held low and pushed with the thumbs behind the blade attachment. The "handles" are there for fingers, but the effort comes from the thumbs. As a result one is working as if with a LA plane, that is, with a low centre of gravity (I refer to this as a low centre of effort, a sailing term).
By contrast, the Stanley/LN/LV work from a higher level. Their handles move the centre of effort higher and wider. There is less direct feedback and feel.
I shall be putting together a pictorial of the build for anyone to copy for their own use, so will just mention that the blade is locked in very solidly, no less so that in the bigger cousins. It is important to secure the blade in the square, otherwise the blade will not cut evenly. There is a simple way to do this. Simple is better to build.
At one point I toyed with the idea of shaping the "handles" ("ears" would be a more appropriate term) by curving them upward from below. However, this would have turned them into handles, which would not be used that way, and also reduced the registration area, which is important (and missing from the small router planes). I have never really enjoyed using the small router planes for hind mortices. This one works well. It is light, nimble, and precise.
roger lance
Derek.....I know I'm interested to see how you have joined the blade shaft to the wood router body....can't quit make out what's going on there. R. Lance
William Duffield
It looks a lot like an eye bolt to me, with a brass knurled nut to tighten it. It would have to be set in a small mortise.
I am also eagerly anticipating the details of Derek's build tutorial.
Jay St. Peter
That's one of my questions also. I think I see what's going on, but not sure. Also interested to see how he went about making it. I have thought about how I'd do it if nobody ever told me. He is pretty clever, so looking forward to how he does it.
Patrick Gibbons
Derek, I always felt the metal routers were tippy, if I can use that as a term. One pushes with the palms. As you said, no feedback. It feels more like I'm hacking wood out.
