New WoodChat!
Hot Hide Glue....
Hot Hide Glue....
Hot Hide Glue....
roger lance
there, that should get the conversation going.....been quiet in here since Tuesday afternoon.... :D
Re: Hot Hide Glue....
Tails first.... glued with hot hide glue
dull as paint (actually oil) drying here
Bill Tindall, E.TN.
I am waiting for oil to dry on my test piece of line and berry. I know better than to proceed to the actual drawers until I prove every step of the proposed finish on a test piece. The proposed finish will be oil to darken the walnut, then varnish or shellac. Staining failed. While I could burnish the holly to not take the pigment stain, there were occasional places where the grain in the stinging tore while leveling. They are not noticeable till the pigment particles lodge in these places and make the stinging look muddy. Probably not obvious from a typical viewing distance but I worried about it and abandoned this approach. Chemical staining colored the holly, to my surprise.
Desperately need to clean the shop. It is amazing how much trash was generated leveling stringing and berries and other sources of chips and shavings. And I expect every hand tool used in last few months is dull. When tools are used off and on over a few month period one looses track of their state.
In the meantime I am designing a flared leg for a modern style desk, a "French Footed" post of a leg. Slow going because I can't draw well. I'll know its right when it gets drawn right but there is a break in the wiring between hand, brain and eye that results in the process becoming trial and error.
Re: dull as paint (actually oil) drying here
roger lance
Bill.....I sincerely want to say that I'm so very impressed by your taking on this project as you have.....your first experience with line and berry and to get the results you did.....just great.....I've said before that I thought you had found your voice....language....in some other walnut pieces you've shown....this piece will just add to it.
