New WoodChat!
Rebirth of wooden jointer planes
Bill Tindall, E.TN.
The invention of electricity doomed the wooden jointer. With the development of the electron driven jointer came the discovery that it could be used to flatten boards before panel assembly, thereby providing an opportunity to repurpose the numerous retired wooden jointers.
Tuning the jointer. Much of the tuning is the same as we are accustomed to. The blade is sharpened and dust removed from the body. Thankfully, the inevitable pits and rust from Ebay Brand planes do not have to be removed, and the use of historically correct abrasive is not required for this application. Finally the blade is set for the desired projection as shown in the picture with the cap iron set well back to eliminate the “Cap Iron Effect”.
The second picture shows the wooden jointer employed, not for the obsolete task of edging, but the more important task of flattening panel lumber.
It is expected that this development will spur the discovery of other uses for wooden planes, for example with the blade removed to be used as sanding blocks with sticky abrasive or mounted upside down to be used as a bench dog.
It is recommended that several be horded before prices increase.
Re: Rebirth of wooden jointer planes
It is April 1st after all.
How about....
John in NM
A toothed blade for combing one's arm hair :D
ROFLMAO!! Great one Bill!
of no use......
Bill Tindall, E.TN.
.......arm hair all gone from testing sharpness.
Dale Lenz
Quit using arm hair....
Dale Lenz
kids started asking if I had some sorta disease, patchy hair on arms. Use newspaper now.
Sure, its made from fir trees
Dale Lenz
Re: Quit using arm hair....
Dale Lenz
I purchase newspaper rolls that are too short for another "run" of print, get from newspaper businesses, called shorts IMMSMC. Two to 5 dollars for maybe a 1000' X 2' ? The paper comes in handy for all kinda things, cover bench prior to finishing, first wrapping on my flag case when packaging them up, etc.
Anyway, after sharpening and honing my tools, plane irons and chiesels, I'll cut through the paper that is rolled up and hanging on the shop wall and see if the cutting edge cuts cleanly or has fine tears in the paper.
