Re: Pardon, my slip is showing
Sgian Dubh
3/8" thick bottoms can be good for larger drawers David, with 1/4" fine for small ones. If 1/4" thick is desired for larger drawers there's always the option of adding a front to back muntin or two so that the span of the 1/4" stuff is reduced meaning there's reduced likelihood of sagging.
Now, with 3/8" thick bottoms there's almost always a need to make some adjustment in the position of the groove in either a quadrant slip or worked directly in the side. The groove can remain the same width at about 1/4" and a shy 1/4" tongue created working from the underside of the bottom. But the groove in the slip or drawer side needs to be raised by an 1/8" or so to prevent the underside of the drawer bottom fouling the carcase construction if it sags or due to wear of the slips or runners, and also so that a decent sized drawer stop can be fashioned.
I always work on the basis that the underside of the drawer bottom should be at least 1/4" up from the bottom edge of the slip or drawer side for the just described reasons, ie, fouling because of sagging, etc and for the creation of a drawer stop. The only exception to this in my working methods is for the very smallest drawers, the sort you might use in small jewellery boxes, or found inside the pigeonholed area of desks, etc. Here you're likely to find drawer bottoms as thin as 1/8" and set up from the bottom edge of the drawer side by as little as 1/8" or 3/16". Drawer sides in these cases might be as thin as the drawer bottom, or perhaps just a bo'hair fatter.
And yes, everyone likes a nicely proportioned or fitted bottom, whatever the political incorrectness of saying such things nowadays, ha, ha. Slainte.
