New WoodChat!
Made a Tool
Made a Tool
Made a Tool
William Duffield
To be precise, I made half a tool.
It's bocote, brass and kingwood.
I do not clock screws. We can discuss that later.
I made it to fit my (left) hand, with detents for thumb and two fingers.
Bottom view. Back side.
Locking knob removed. Showing threaded insert.
So, can you figure out what it's for? I left a hint in another post.
Re: Made a Tool
Stephen Shepherd
Nicest one of those I have ever seen.
Re: Made a Tool
Re: Made a Tool
CStanford
Is for for floating toy army men across the Cohansey?
Re: Made a Tool
Would that float?
Bruce, a MN Galoot
But I do agree that I've never seen a nicer one.
Re: Made a Tool
Re: Another Hint
William Duffield
It's for Federal furniture. You can find pieces of it in this mock-up concept tool box.
I just noticed on Lee-Valley's website that the mini-t-loc systainers will be offered again in May at the introductory price, when they get more in stock.
Re: Made a Tool
Re: Made a Tool
William Duffield
It's a straight line stringing cutter, for cutting the grooves for inlay on Federal period table legs, and also for straight line inlay in the Chester County line and berry decorative style, as illustrated here by Bill Tindall.
Specifically, it is designed to hold the head of this radius stringing cutter made by Lie-Nielsen.
Lie-Nielsen and Veritas both make a tool that does this job, and Veritas also makes a special purpose head for their router plane that will do it. The issue with all these tools is that they use a different set of blades than their radius cutters, which might therefore be a different thickness. The router plane attachment gets even more complicated, as it uses a pair of blades and a stack of shims to adjust the thickness.
Since I already have a L-N radius cutter, I realized it would be asking for a lot less trouble if I just swapped the head between two fences, avoiding the issue of getting out the calipers to make sure I had the same width blade installed in two different tools.
The L-N system:
Lie-Nielsen Inlay Tools
The Lee Valley system:
Veritas® String Inlay Tool System
Stay tuned! Later, I'll compulsively point out all the egregious errors I made in designing and building it. Seriously, I hope someone may be inspired to make one of their own, so I'll try to offer some suggestions that will make yours better than mine.
Re: Made a Tool
Re: Made a Tool
William Duffield
First issue: The brass shaft of the locking knob is a little too long, and the knob therefore sticks out like a sore thumb. I'll grind off about 1/8". This is so trivial that it's almost not worth mentioning, except to point out that if you make it too short, you have to start over. Since it's already glued into the wooden knob, I'll have to grind off the end that shows, which is turned on the lathe, not sawn with a hacksaw. This modification will be visible.
You could make the knob itself a little smaller, without sacrificing any functionality. I started with a 6/4 square block of kingwood, and stopped turning as soon as I got something I liked. Further work would have wasted time and valuable wood.
I installed the threaded insert for the locking knob into end grain. This means that the longest dimension of the wear plate is cross grain, and therefore subject to the maximum seasonal movement of the block of bocote. The blank should be laid out with the grain running horizontally. During installation of the threaded insert, the block had some threads torn out, which weakens it, and can even result in pulling the insert out if the knob is tightened too much. To ameliorate the problem, I ran some thin CA glue into the threads. It's holding, but epoxy would have been more secure. You would have less problems with this if you used a softer, less dense wood.
The wear plate is 1" x 1/8" brass. You notice the extra weight, both of the brass and the dense bocote. 3/4" x 1/16" plate would be sufficient, but I used what I had on hand. I'm not sure a wear plate is even necessary if the fence is a dense tropical hardwood, but the L-N has one and the Veritas fence is all brass, so I equipped mine with one. It is held in place with four #4x5/8" slotted brass FHWS. I probably should have given the back of the brass plate and the wood behind it some tooth, and attached the plate with epoxy. That would have saved a lot of effort, since there would be no holes to drill and countersink, no pilot holes to drill in the wood, no screwdriver to modify to exactly fit the slots, no screws to install, no risk of messing up a slot or twisting off a screw, or breaking off a tiny Vix bit. The plate would have been easier to polish, too. "To clock or not to clock" would also not have been an issue.
The depth stop pins are 5/16" round brass rod. 1/4" or maybe even 3/16" if you made them shorter would have been sufficient, but, again, I used what I had on hand.
I mislocated the depth stop pins. The cutter is exposed 5/32" below them. 3/32" would have been much better. The slots in the L-N cutters are elongated, so I figured they would be adjustable for depth, but they are not. I'll have to elongate them a little more, probably using a diamond rat tail file, if I want to retract the cutters.
Even though you would usually cut on the pull stroke, for purposes of the following discussion, front is towards your fingers and rear is towards your wrist, as if you were cutting on the push stroke. Left and right don't work, since you may make yours "backwards" for use in your right hand. I positioned the cutter towards the front of the fence to provide the most secure, repeatable grip, as shown in the photo. This puts the front depth stop pin too close to the cutter, especially if the cutter is too deep, because you have to extensively bend your wrist downward to engage the cutter and the front pin at the same time. If you get the pins at the right height and move the front pin forward an inch or so the problem goes away. There's an easy fix: Make the fence longer.
The rods on the L-N cutter are not quite parallel (I'm sure there is a very good reason for that), so even though I very precisely laid out and drilled the holes for the rods, I still got a little binding when it was adjusted to minimum depth, so I had some tweaking to do on the holes in the fence with a chain saw file.
Does anyone want dimensions? I hope not, because I took all my dimensions off of the stock I had on hand, and the overall height, width and length are either arbitrary or should be changed anyway.
Re: Made a Tool
Re: To Clock or Not to Clock?
William Duffield
I'm not talking about the Anaheim, Azusa and Cucamonga…Timing Association.
I've noticed Stephen often introduces a suggestion to clock screws. Doing so certainly adds a lot of additional elegance to a tool, but without an immense amount of additional work on a new tool, I don't think it is really practical. When repairing stripped out threads, as Stephen suggested to Ron in the thread on the wooden plough plane repairs, it makes sense to do it, because the new threads are temporarily pliable. However, on new construction, the only way I can see that it would work is if screws with oversize heads are installed, a new set of clocked slots is cut, and then the tops of the heads are milled off, removing the original slots. Otherwise, you can substantially weaken the strength of the attachment. Instead, when installing screws in wood, especially soft brass screws in dense tropical hardwood, the screws should be driven in to a consistent torque. If you try to clock them, you can either strip out the wood threads or snap off the screw head. This is because you have no real control over where the screw starts cutting, and to get them to all line up, you may have to over tighten some of them as much as a half of a turn.
If you are using Phillips or Robertson head screws, you reduce the stress to a maximum of a quarter turn, but notice that the Phillips head screws in the L-N straight line stringing tool are not clocked. If you used Allen head or Torx head screws, you could limit the stress to a sixth of a turn.
Assuming I'm going to clock my screws, if I have, for example, a horizontal row of them, should I align the slots horizontally or vertically?
Re: Made a Tool
roger lance
Vote to clock....but suggest using a steel screw of same size as your brass screws to first make its way into hard wood before installing the brass screw.
Re: Made a Tool
CStanford
Make them all point to the Cohansey when the tool is pointing at True North.
Re: Made a Tool
David Barnett
(Message Deleted by Poster)
Re: Made a Tool
How did the old guys do it?
Ron Harper
The steel screw of the same pitch makes sense to me......then there is the puzzle of how to control where the screw engages. ....and do different species of timber behave the same?
Clocking seems to be a very big deal in some circles. I have not yet attained to the level of accomplishment where the issue becomes germane. :). I have a hurdle or two before I get there.
Re: Made a Tool
Re: Timing screws
William Duffield
Aha! Thanks, David, I've learned something useful. When you explained how it's done, my reaction was "Now, why didn't I think of that?"
Re: Made a Tool
Re: How did the old guys do it?
William Duffield
I always use the steel screw when I have one that fits. I also wax it. I wish the people who source the brass screws I use would put one steel screw in each box.
Re: Made a Tool
Yes and
Ron Harper
As a power tool guy, I was never really very careful about pilot holes with shank clearance. I just grabbed a half horse drill motor and "drove them home". There is a reason the Brits have always used the term "turnscrew" they are meant to be turned not driven.
Re: Made a Tool
Re: Timing screws
TomD
That is an interesting article, thanks for that. The only method I was aware of was the one with the oversize screw, which if you have a lathe with which to undercut screws, I prefer to just make my own screws as required. I guess brownells sell the parts, but I would have to stock so many parts vs. any likely use, it seems pointless. Slotting saws are cheap and make cutting screw heads pretty easy.
The other two methods seem like bodges, and hand filling the underside of the screw sounds like a bad idea. I would rather have a real bearing, than an alignment that might not even last, and loading that was uneven. I would probably prefer to turn it against some kind of reamer if I had to.
Re: Made a Tool
A "fly in your ointment"
Bill Tindall, E.TN.
The holder is an elegant solution to something that isn't a problem. The concern about winding up with different width troughs by using the two tools is unfounded. You will discover in use that the cutter used for radius cutting is ill suited for cutting straight lines in long grain, especially in softer woods like a mild walnut of mahogany. The easy flex of the narrow circle cutting blade and the cross cut teeth can result in blade deflection which will result in varying trough widths.
The place to focus effort is in tooth pattern. The problem to be solved is "chip' clearance. While the three tooth LN straight line cutter excels for cross cuts where the chips break into small pieces, and it was for good reason that three teeth were used by Latta and LN, it does not clear chips in long grain. Long strings stack up in the trough and jam the cross cut teeth.
For Federal legs where only rip troughs are required a custom ground rip tooth cutter will be more effective. It could be as simple as a piece of sharpened card stock screwed to the side of a rabbited piece of maple as I saw in the shop that does restoration for Christies, Sothaby's and the furniture brothers from Antiques Road Show (more on that later).
Re: Made a Tool
Re: A "fly in your ointment"
William Duffield
Thank you for the advice, and your experience. I guess I could still use it for cross grain on the ends of drawer fronts? I'm surprised that the blades would flex that much in use, but will keep my eye on it on scrap before I try it on any real projects. I now have another idea, however. Maybe I could sharpen the other end of the L-N blades in a rip tooth/scraper pattern, and then just turn the blade over?
Re: Made a Tool
now you're on the right track....
Bill Tindall, E.TN.
"Maybe I could sharpen the other end of the L-N blades in a rip tooth/scraper pattern, and then just turn the blade over?"
Very easy to do with a very small file. We made one in class in a minute or less.
The fact that you can see the cutter whilst cutting with this cutter is a huge advantage...... especially at the start and stop.
Re: Made a Tool
Re: Correction
William Duffield
In the previous post, I stated, "The slots in the L-N cutters are elongated, so I figured they would be adjustable for depth, but they are not." I was wrong. The cutters are adjustable for depth. The adjustment is just enough that I can correct my problem with mislocating the pins. The tolerances between the cutters and the tool head are very tight, so the cutters do not slide easily. The two photos show the range of adjustment.
Re: Made a Tool
Re: now you're on the right track....
William Duffield
I checked one of the blades, the thinnest one, and it does have a perceptible amount of flex, just as you experienced. Whether I can control it, or even see what's happening as it happens, will have to wait a week or so. I have to go out of town for family.
They are hardened steel, but L-N doesn't state to what hardness. I hope they are the same as their saws, so shaping them shouldn't be a problem. In any case, if they are harder than my chainsaw files, I have some diamond files on order that will work.
Re: Made a Tool
scott grandstaff
Re: Made a Tool
scott grandstaff
I love this!! The detents are very cool!
Oh, to cut an overlong screw, just thread a handy nut on it past where you need to cut. Then you can lop it off and grind or file it to any length you really need.
When you take the nut back off, it chases the treads for you so it starts easy.
PS I wouldn't clock screws at gunpoint!
I take great perverse pleasure in tweaking the poor little OCD schlubs who think they need it. Its good for them. heh
yours Scott
Re: Made a Tool
Re: Made a Tool
William Duffield, Going to Winter Haven
That's a great tip, Scott, but, alas, it wont work in this case. If you take a close look at the last photo in my first post in this thread, you'll see that I turned off the first inch and a half or so of thread, so it doesn't take so many turns to extract the knob from the threaded insert.
