Hide glue query
Ron Harper
If you use it, how are you heating it?
Hide glue query
Ron Harper
Re: Hide glue query
Bob Entwisle in NJ
I use a cheap mini crock pot filled with water, then the glue in a jelly jar set into the crock pot. to set it up, I tossed the jelly jar in filled with water and stuck a thermometer in it and tweaked the thermostat until it gave me around 140-150°F.
Bob in NJ
Re: Hide glue query
Don Stephan
The commercial hot hide glue pot.
Re: Hide glue query
Ron Harper
That is what I have done in the past, without the thermometer. Probably ouhgta break down and buy a thermometer. Thanks Bob
Coffee cup warmer
John in NM
Glue pot is a 1 1/2" copper pipe cap, I rarely make anything very big any more. That cap used to be really cheap, these days it will probably run $10 or so. I do find that the water cooks off within an hour if I inadvertently leave it on. The low humidity out here doesn't help
One day I ought to get a larger set up going. Little crock pots are inexpensive enough that I should just pick one up. I'd love to have a nice glue pot, but I'm afraid I'm a real cheapskate
Re: Hide glue query
Ron Harper
That is what I have done in the past, without the thermometer. Probably oughta break down and buy a thermometer. Thanks Bob
Me too John
Re: Hide glue query
William Duffield
Two problems: The thermostats on cheap crock pots are not very stable. If you get the glue over 150° it cooks, which means the protein breaks down, and it doesn't work as glue any more. So you really need a thermometer, and you need to watch it carefully.
Oh, yeah, I also use a cheap plastic potpourri crock pot, and a baby food jar, and a candy/deep fry thermometer. Right now, I'm working on two issues: replacing the cheap plastic lid with something a bit sturdier that provides a little more thermal insulation, and making a rack for under the baby food jar to keep it away from the heating element. I won't tell you what I tried last because, while it seemed like a good idea at the time, it failed miserably for two reasons which should have been obvious to me.
Re: Hide glue query
TomD
I started out with a baby bottle warmer. It was great, unfortunately the new ones use steam, or something, that I could find.
Since then I use a real glue pot, but they are too big for most jobs I do.
Currently I have a small crock pot. I use a plastic bottle with a stainless rod in it to keep the heat up. It rests in the pot, with enough marbles in it that the water level is just right for the bottle. This is a typical lutherie set-up, that allows you to use the glue as though it was regular glue in a squeeze bottle. You can find info on this set-up all over the net.
Currently I am making a pot out of a 1.5" copper pipe end. I welded a copper union above it for the greater height it provides. I turned the cap on a lathe to increase it's contact with the element. Which is:
http://www.lmii.com/CartTwo/thirdproducts.asp?NameProdHeader=Brass+Glue+Pot
I use a warming blanket made out of carbon felt.
Re: Thermometer
TomD
I use a thermocouple. They used to be expensive but a lot of electronic testers have them as an add on, you can get them for 99 cents, ebay. Another option would be something like this:
http://www.ebay.com/itm/K-Type-Digital-Thermometer-thermodetector-1300-C-TM-902C-Thermocouple-Probe-/170968632720?_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D163%26meid%3D6321547835415654407%26pid%3D100005%26prg%3D1088%26rk%3D4%26sd%3D320967225183%26
Re: Thermometer
Robin Corell in Atascadero,CA
I also use a mini crock pot, but I put the glue directly in the crock pot. I control the temperature by plugging the crock pot into a variac.
my crock pot has a plastic lid which I notched with a dremel so I can stick a thermometer in the pot without losing much moisture to evaporation.
Robin
Re: Hide glue query
Jack Guzman from Maine
I use a rival hot pot. I cut a hole in the top just big enough to fit the body of a small mason type jar sold as canning supplies. The raised bead around the jar just below the top keeps the jar suspended above the heating surface. ---Jack
rack...
John in NM
William, if you can find a scrap of expanded metal, cut it into a square small enough to fit in the pot once the corners are bent down. I did that for a vacuum chamber I made. If the rust bothers you, SS expanded sheet is available in small pieces from outfits like McMaster Carr, and probably Online Metals.
If I was on a proper, well behaved computer, I think I would have a picture of what I made. Let me know if you want to see a picture and I'll go downstairs and see if I have one.
Re: rack...
William Duffield
I considered that approach, but couldn't find any metal lath laying around the shop. I considered plastic egg-crate fluorescent fixture diffusers, but couldn't find any of that laying around either, and it's $20 in driving expense to the nearest Blue or Orange Borg. Then I got an idea.
I drilled a lot of holes in a piece of 3/8" mahogany and put some sipo dominos in the bottom to keep it off the element. It floated (why hadn't I thought of that?), but that wasn't so bad, since the baby food jar held it down, but by the next morning, it had soaked up a lot of water, and expanded. I had cut it pretty close to the i.d. of the pot. Luckily, it popped up out of the pot, instead of splitting it. Maybe I should have used lignum vitae or acrylic, or coated the mahogany with West 105 and 207? I have some copper wire, which I could bend into a proper shape, but it's 8 gauge and the shape is complicated. Also, I pour out the pot onto the ferns outside the shop door, and ferns really, really don't like copper.
Come to think of it...
John in NM
I have lots of metal lathe lying around, the really flexible stuff for plastering, also known as blood wire (anyone who has used it will know exactly why). I was thinking of heavier stuff in my first post. I'll send you a piece if the light stuff will work for you. It will still rust, but at least wouldn't kill your ferns.
Re: Hide glue query
William Duffield
Thanks for that tip, Jack. I'd been looking at canning jars, but the standard Mason jars were wider at the bottom than at the top. I just found an 8 oz. quilted jelly canning jar by Ball that is the requisite shape. End of futile search for rack! Now, the mission is to smuggle it out of the kitchen and find a matching Forstner bit. I'll also need a lid, so I can store any leftover glue in the shop freezer.
The pic is of 4 oz. jars, but the concept is the same. If the 8 oz. jar turns out to be too tall, and touches the heating element, I can just make the top a little thicker.
Re: Come to think of it...
William Duffield
Thanks, John, but I think I've solved my problem. See my reply to Jack's post above. My dad used to be a plasterer, so I know why you would call it blood wire. I think it comes in aluminum as well as steel.
Glad you got it figured out...
John in NM
I'll have to remember those jars if I ever get my act together with a larger capacity set up. I like the shape of those. They would also be good for storing finishes like Waterlox in small quanties. I used to have a heck of a time collecting enough little jars to store a full gallon.
Re: Glad you got it figured out...
William Duffield
You can get them new by the dozen, with rings and lids, for about a buck apiece. The lids and rings are sold separately at any big grocery store. You can also find jars and rings at yard sales for approximately free, at least in the Garden State, but the lids are not reusable, at least if you are going to store food in them. Rings are sold separately because they eventually rust when stored in the cellar.
OTOH, for Waterlox, Bloxygen is a lot easier to use, since you don't have to divvy up the finish and put labels on all the small jars*. Note, however, that when you pour out the finish, you also pour out the magic (argon), so you have to add more every time you open the Waterlox, unless you pipette it.
* SWMBO is a CIH, so she is a stickler for always labeling decanted chemicals.
I use it in small quantities...
John in NM
That is why I like the small jars. Once a jar is opened and used a few times, I figure it's a gonner if I don't have a lot of projects lined up to finish. A small jar is just about right for small tables and stuff, that is where I got the habit I think.
Once I get a bottle for my tig welder, I will probably try the oxygen displacement route. Come to think of it, I'm too cheap to buy bloxygen, I'm probably too cheap to buy single use bottles too
Back to fishing old jam jars out of the trash I guess.
mason jars
One thing I like about those jars is the seal cap. When in use I remove the screw-on cap and when it sits idle I can leave the little sealing cap on to avoid evaporation. I store my glue brush in the hot water through the spout.William,the 8oz jars are what I use,they only set about halfway into the pot.---Jack
Re: Nailed It! *LINK*
William Duffield
I made a quick modification to the new lid I'd been making for my hot pot. I drilled a 2-5/8" hole somewhere near the center with a Forstner bit. The lid is made from two pieces of 1/4" plywood, glued together with Titebond III.
A view from the bottom of the lid with a hole for the Bell jar and another for the thermometer.
Another, with the lid, jar and thermometer in place. After I've dripped hide glue on it a few times, the patina of the new lid will match the old, discolored plastic pot.
The hot pot has a Rival brand on it, but the only one currently offered by Amazon that is the same is labeled Sunbeam.
There are a few things I don't like about the pot, but it does the job, and it was cheap. The cord is too short, and too stiff, so when the very light pot is empty, it's difficult to put it where you want it on the bench and have it stay there.
I also use it, without the lid, for warming up a bottle of Franklin liquid hide glue, which gels in my shop in the winter.
Re: mason jars
William Duffield
Oops, missed one detail in the post above. In my pot with my new lid, the bottom of the 8 oz. jar is 3/4" above the heating element, which is just about optimum, IMHO. Since my lid closes off the spout, I guess I'm going to have to drill another hole in the lid to drop the glue brush through.
Re: Continuous use?
TomD
Does anyone know whether any of these appliances are more or less safe for continuous use? The crock pots are presumably rated for it, as would be the industrial glue pots. Probably the coffee warmers. The actual glue pot warmer LMII sells is presumably up to it, and it is not expensive. Just curious. I don't use my glue pot continuously, just when I am in the thick of a project like guitars.
Re: Nailed It!
Mine is the same thing. I found it in a yard sale for a dollar. I hate that short cord. I may just put a new cord on it if it isn't hard to rewire.I also use mine for a hot water source for removing old hide glue when repairing furniture.I like your lid.---Jack
