An interesting work holding idea. *LINK*
Leo Cuellar
I stumbled across this one today. Looks like it could be a handy alternative in some situations.
http://garagewoodworks.com/garage_blog/2012/02/20/bernoulli-spiral-clamps/
Leo Cuellar
Re: An interesting work holding idea.
roger lance
Leo....here's another work holder that's based on the wedge....
it also comes in handy at times.
(Message Deleted by Poster)
Bill Tindall, E.TN.
neat idea...have you tried it yet?
Larry Barrett
Looks like this would work well on William's swiss cheese meta-bench.
roger lance
This idea has long been used in sailing to secure ropes from being pulled out of place.....see cam cleats.
Leo Cuellar
Yes, and also for holding your long handled tools in the closet or garage, etc.
Leo Cuellar
Been there done that and everything else as well.
Leo Cuellar
Not yet, Bill, but I'll be making a set when I get time.
Leo Cuellar
I think anything would work well on that device, it is seriously cool.
Re: And another: Nautilus cams + video
Leo Cuellar
I imagine that they would work well no matter how big or small they are: say a miniature pair for one of the little handheld vises? I like that they are deployable in a few seconds.
AlanWS
For handplaning, it might be more compact and effective to use only one cam to hold the work against a flat surface.
TomD
There is noting new about cams, a novel use is still a novel use.
TomD
That is what I was thinking, two cams does not increase the force, one cam would convert all the back pressure into lateral force, and the use of a solid side would increase friction, lower bruising, and also if the fixed side were at the bench edge keep the work more under the shoulder.
Re: A Flawed Work Holding Idea
William Duffield
Hmm. I build a pair of these clamps a few years ago, but never thought to try them on the Loxiliary Bench. I'll have to give them a try. As shown in my photo, I think they are more useful for carving than for working with rectilinear stock, as shown in the video Larry provided.
My clamps didn't work as well as I had hoped because I got the angle of the logarithmic spiral a little too steep for the most effective grip on wood. I think 10°, as shown in the first figure in the following linked article, should be appropriate for hardwoods, but only if you are clamping between a cam and a flat surface. If you are clamping between two cams, then I think a 5° spiral for each cam would be more effective. However, more experimentation is needed. Since the effective range of motion of a cam with this shallow of an angle is much smaller than the golden spiral, it requires a lot more dog holes, spaced much closer together, to grip any arbitrary width of stock. Perhaps the application of PSA sandpaper would allow a larger angle to be effective.
http://en.wikipedia.org/wiki/Logarithmic_spiral
Right now, the Loxiliary bench is in the back of my vehicle, under a mini-lathe, a work-mutt, a pile of extension cords, three overloaded tool boxes, and a roll of Ceylon Satinwood veneer, as I got home from three days at the Somerset Woodworking Show late yesterday evening, and my tail was dragging. I was there demonstrating the bench and some tool making techniques. It will take most of today to get everything unloaded, back into the Toolworks, and put away, and then maybe I can try out the cam clamps.
Note that the clamps in the video that David Barnett posted, since they are a Fibonacci spiral, laid out with a compass, instead of using an appropriate formula to generate the Golden logarithmic spiral that he is trying to approximate, do not have "an angle." In other words, it varies as the clamps are rotated. Also, I note that he is not very careful to even follow with his bandsaw the spiral he drew. Even if he got it right, IMHO, the golden spiral is much too steep for effective holding of hardwoods.
http://en.wikipedia.org/wiki/Golden_spiral
Also, I understand why he thinks loose dowels are an advantage (they're not), because that allows them to stack more easily, but it also means that the dowels can become separated from the cam clamps and lost, or fall through the dog holes in the bench. It also takes longer to set them up and take them down, because there are a lot more pieces to handle. Instead, I would glue and wedge the dowels into the clamps, and to make them stackable, drill another oversized hole or two in each clamp. Of course, if you glue in the dowels, you have to make sure you make two left-handed and two right-handed cams, instead of four the same.
roger lance
A strip of 100 grit psa should make a significant difference.
William Duffield
Yes, unless you've already finish planed or sanded the surface you need to grip.
David Weaver
How about those $3 rolls of tool chest rubber that HF carries. A strip of those would improve things, and wouldn't mark a piece.
roger lance
or some of that rubber matting that LV sells....it has an adhesive underside.....25K01.11 for example.
