Is gluing mechanical locking or adhesion?
Bill Tindall, E.TN.
This question is relevant to the toothing discussion below. If you want to glue two pieces of metal together the surfaces are machined and lapped perfectly planar and smooth. In a long ago demonstration of cyanoacrylate adhesive, then known as Eastman 910, the ends of two 2 " bars (may have been 2.5") were so prepared, a drop of the adhesive placed on one surface and then the surfaces were mated. One bar was fastened to a crane, the other to a car with the adhesive's inventor inside. The car and inventor were successfully hoisted into the air.
In principle, only two monolayers of something tough and strong that will wet each surface are needed to provide adhesion. Virginia Tech has an adhesives program and I had occasion to ask one of the researchers whether wood is stuck together by adhesion or mechanical interlocking. He responded that given the porous nature of wood it would be difficult to separate the two possibilities, but that the mechanical part is not essential to stick wood, or anything else together by adhesion.
Speculation: Veneer is not going to be easy to plane given that it is mechanically weaker than a board. Could it be that a toothing plane with its may teeth exerts less planing force on the veneer during planing and that is the whole of it?
