New WoodChat!
Barnes mortiser
Barnes mortiser
Barnes mortiser
Ron Harper
I promised a pic of my new find.
Help please any tips on use?
I will hone chisels tomorrow. How much stock needs
to be removed with a drill before chopping?
Alignment seems to be fussy. Obviously, when you flip the stock end for end, you either have to be dead nuts centered, or re-align the chisel, or the mortise will have a kink in it.
Re: Barnes mortiser
Re: Barnes mortiser
JiminVA
Ron,
In soft pine, you don't need to remove any stock before you mortise with the machine. (I think a lot of these marchines were used in sash shops and they were dealing with mostly soft wood.) However, I generally drill one hole in the center of the mortise to give the waste some place to go. It's faster.
I'm confused about your comment regarding turning the wood around. You never have to do that. The handle with the ball on the top is used to change the orientation of the chisel. It indexes into little grooves so you can spin the chisel 180 degrees and have it lined up perfectly. Cut the left side of the mortise, spin the chisel 180 degree, and cut the right side of the mortise.
Easy! Have fun with you new toy!
Regards,
Jim
Re: Barnes mortiser
Hardwood and comment
Ron Harper
When I spin the chisel 180 and lock it, it is off line with th previous cuts maybe 3/64ths.
In hardwood do you just bore out the mortise and square up with the mortiser?
I have not honed the chisels yet, but I can 't get much of a cut in hardwood
Re: Barnes mortiser
Re: Hardwood and comment
JiminVA
That is very curious about the chisel being offset. Mine is dead nuts on when I spin it. Is your chisel parallel to the fence? That might do it if it is not aligned properly. If it is aligned then either the mortiser is off and all chisels will be so affected or the particular chisel is not quite right. If you remove the chisel and reinstall it facing the opposite direction does it line up with the mortise? If so, the chisel is ok and the mortiser is off. You could also try a different chisel if you have more than one.
For hardwood I have drilled out most of the waste and then used the mortiser to square up the mortise. I keep my chisels really sharp and they go through the wood pretty easily with a satisfying "schwwick" sound. Just be really careful because the mortiser will cut through a hand without even knowing it's there. DAMHIKT.
Re: Barnes mortiser
How to?
Ron Harper
With the morse taper,how do you get the chisel square to the fence?
Re: Barnes mortiser
Will someone explain how this tool works?
Bill Tindall, E.TN.
Maybe I'm the only one but I have never seen nor heard of this tool and don't fathom its operation from the picture. I'm thinking some 1920 version of the hollow chisel mortiser but I don't see a drill.
Re: Barnes mortiser
Re: Will someone explain how this tool works? *LINK*
wilbur
It's a foot powered mortiser. You step on a pedal, which drives the chisel down, instead of hammering on the chisel. I've never used one myself, but I would guess that between using your leg muscles and maybe having some mechanical advantage with the lever, that this would be somewhat easier than pounding on a mortise chisel.
There's a bow (wooden or metal, depending on the model) that bends as you step down on the pedal, which provides the force to spring the chisel back up.
Here's a YouTube video that gives a good tour of how the mortiser looks, and a demonstration at the end.
Video of a Barnes mortiser
Re: Barnes mortiser
New info for Jim and others
Ron Harper
I forgot to check if the table is level front to back, but this still should not cause this condition. I have the front edge of the chisel square to the fence. I double checked by squaring a line across the edge of the board. When I line up the chisel between my gauge lines with the flat of the chisel to my left. Then flip the chisel so the flat is facing right, the line of cut moves almost a sixteenth to the back of the table( away from me). I can find no adjustment that would govern this. I am baffled. Now ,it is a relatively easy mid mortise fix. I loosen the lever and tap the assembly into line. I should not have to do that
I have learned that the issue with hardwood is not cutting. I found this out by cutting mortises for bridle joints on the ends of walnut and cherry stock. Very cleanly slices through the boards with not a whole lot off effort. The issue for hardwood is mortise bit clearance. For a quarter inch mortise, a quarter inch hole is not enough room for the mortise bit to get out of the way of itself in hard woods. In pine it can sort of muscle its way through.
Any ideas about the alignment issue?
Re: Barnes mortiser
It really is a paring tool
Re: Barnes mortiser
Pic for Jim
Ron Harper
This is not a very good photo, but you can see what I mean. Itvwas taken last night before I squared the chisel, but today's resultvwas almost identical
Re: Barnes mortiser
Re: What you really want…
William Duffield
…is one of these:
http://www.festool.com/EN/Products/Pages/Product-Detail.aspx?pid=574320&name=DOMINO-joining-system-DF-700-EQ-Plus
Sorry, it doesn't have hairy paw feet, but all your alignment and sharpening problems will be a thing of the past. It takes up a lot less shop floor space, and won't bang up your shins. Changing mortising chisels is a lot easier. No more worries about fitting your tenons to your mortises. Oh, it does require dust collection, which adds a bit more to the noise.
Ducking and Running!
Re: Barnes mortiser
Nope
Ron Harper
I will pass. That phase of my life has been completed. Probably shouldn't even have bought the foot powered jobbie. I am weak, and is it so awesomely cool.
Not sure how practical it is gonna be in hardwood, but I made major strides today.
Re: Barnes mortiser
Re: New info for Jim and others
Robin Corell in Atascadero CA
Sounds like your chisel is bent.
Robin
Re: Barnes mortiser
That is not it
Re: Barnes mortiser
Gary Hodgin
Neat machine. I thought it might be some sort of 19th Century torture device until I saw the guy use it.
Re: Barnes mortiser
Patrick Gibbons
Are you sure the chisel enters 90 degrees to the wood? If it's a few degrees off the chisel will enter at a different point when rotated. If so, rotating the wood would be an alternative. The alignment of the chisel must be the issue.
Re: Barnes mortiser
Ron Harper
I will try again when I get home on Sat, but I used a machinist"s square to scribe a line across the piece and the chisel looked dead square to it.
Re: Barnes mortiser
Re: Nope
William Duffield
I was only kidding you, Ron. While the Festool Domino machines make precision mortise and tenon joinery "all too easy," one loses a lot in the process, including the satisfaction of well executed skills, the feedback from the wood, and lots of flexibility of design. Exposed Domino joinery has "power tool" written all over it, similar to router cut dovetails.
The Barnes machine is kewl, but in other than an industrial environment, I wonder how much better its performance would be than a mortise gauge, EOBM chisel and a hefty mallet? You also have to wonder whether these things were worth the maintenance costs (especially with the alignment problems yours evidences), and were an experiment that never took off, or if maybe they were soon replaced with motorized hollow chisel mortisers?
Re: Barnes mortiser
I know you were kidding
Ron Harper
I agree with you that a skilled craftsman with hand tools will give this this a run for the money in hard wood. I think that in a door or sash shop in 1840 they were a timesaver in mortising soft woods.
Re: Barnes mortiser
Patrick Gibbons
Ron, As you've shown us, the chisel is not rotating on its axis. It shifts at 180 degrees. If it cuts square to the stock after rotating my first suggestion was wrong. I don't have any experience with this machine but your problem makes me wonder. The first item I would concentrate on is the chisel holding mechanism and its rotating aspect. Sorry I can't recommend anything other than the obvious. Let us know what the problem is when you ascertain it.
Re: Barnes mortiser
Ooops you were right
