New WoodChat!
scraper stock source
Bill Tindall, E.TN.
Steve Latta cuts up Lee Valley 0.032" scraper blades for this application. Alternatively, if there is a saw shop handy, get a piece of 0.032" band saw blade stock from them.
Either stock can be sheared if you have access to a shear or a machine shop with a shear. Alternatively a Dremel with a cut off blade works well. Clamp a piece of 1/2" wood along the line to be cut and use it as a guide for the cutoff wheel. Or, a very fine tooth hand saw blade with cut it. Again, support with a block of wood.
Thick stuff has no advantage that I know of. It just makes filing the profile more tedious. Needle files and a set of chain saw files of various diameter will make most profiles.
Re: scraper stock source
roger lance
Thanks Bill....when it comes to working with metal, I'm basically a "babe in the woods".....I know to go to my local chainsaw shop for files.....at this point, I'm really only interested in three beading cutters....1/4", 3/8", and 1/2" beads.....so I'll see what size files they have.....my interest in thicker stock was based on my assumption that thicker would be more durable and less likely to bend....I did pick up some of the Hock replacement blades at the local Woodcraft and they happen to be 3/4" wide and fit my beading tool on the money....they are very secure in that little pocket I made for cutters....so things are coming along on that front.
TomD
I do a lot of finishing with the thinnest scraper stock that LV has, OK just looked they have thinner stuff now... But they do heat up faster, and there is more hand strain. I just like the cut. For scratch stocks, too thin could mean chatter, or edge loss due to overheating. I think the stock bits are about 1/16" And I could do with their being thicker.
You can also get a lot of rough out done by drilling a hole through the stock. Braces will drill steel, drill presses, or screw guns on slow. Sharp bit, slow turn, lots of feed pressure. If you are using power, you need something to hold the bit.
TomD
Actually, they are both bits, the drill and the scratch stock bit, so I meant to say you need to hold the scratch stock.
