New WoodChat!
LN blade/chipbreaker on Stanley plane
Ray Bohn
Has anyone successfully used a LN blade/chipbreaker on a Stanley no 2 plane?
If not, could someone forward the measurements for an original no 2 chipbreaker (see image)? Since I do not have the original chipbreaker to measure, I didn't want to contact LN yet.
It appears as if Veritas may be the only other supplier. I was unable to find anything on websites for Hock and Highland. Although I did send a query to Hock Tool.
Re: LN blade/chipbreaker on Stanley plane
Ray Bohn
Sorry about the typo in the subject line. I couldn't find an "edit" button
Can't find an "edit" button?  You need a profile! *LINK*
The edit button (for up to two hours after you post a message) is one of the features you'll have available if you establish a profile, which can be done following the instructions at the link below. One very important note: you've posted messages, so you must delete Wood Central-related cookies before you start the process to establish a profile; otherwise, you can't complete the steps.
Welcome to Wood Central, and I hope someone more knowledgeable than I about Stanley No. 2 planes comes along in a minute to help.
I repaired the typo in your message title.
Bill Houghton, one of the moderators
http://www.woodcentral.com/faq/profiles.html
Re: Can't find an "edit" button?  You need a profi
Ray Bohn
Bill,
Thanks for the help. I am trying to determine if I bought a Frankenplane and if it is financially feasible to get it back to at least useable condition.
Bruce, a MN Galoot
I don't know what you paid, Ray, so that might make a difference to you. FWIW, I saw a collector pay $400 for two #2's at Medina on Saturday.
James Watriss
I've done it. There's a lot of backlash, but it's functional. I had the thought to braze beads onto the back of the cap iron to catch the yoke better, but it was simply easier to buy a hock blade in the end... Their A-2 seems to be better, and the thinner blade reduced backlash considerably. (I think L-N actually does offer thinner aftermarket blades, too, for vintage planes.)
Timing is everything... I actually have that Hock blade up on eBay right now.
Ray Bohn
James,
Thanks for the reply. Are you saying that you successfully used a LN chip breaker with a Hock blade? Was this on a no 2 or 602?
I am trying to determine if the blades and chip breakers are the same on these two planes.
Do you know the "Type" or general era of your plane? I have been told that the LN set works on earlier planes but not on later versions-1930s.
Thanks again
Ray Bohn
Bruce,
I have calmed down and have accepted my loss. Now I would like to get this hunk into working order. I am pretty sure that I need at least a chip breaker, a yolk/pin and maybe adjustment wheel. Everything is beyond loose. I would like a correct, original chip breaker if possible. The plane is a type 3-602. Can you or someone you know suggest a source for these parts?
I have never replaced any of the depth adjustment parts on a plane, but I think it looks pretty straight forward.
Thanks
Bruce, a MN Galoot
A couple come to mind, well, three. First try John Walkowiak from WN. He's from Mpls and had the tables in the SE corner of the Medina show. Then try Walt Quadrato at Brass City Records. He has everything or can find it. Don't email him, call his phone, listed on his website. Last, not least, Patrick Leach has everything, too. Leach@supertool.com
James Watriss
I did this on a 4, not a 2. But there aren't any issues that would prohibit this working on a 2, or a 602.
Aftermarket chip breakers will work, regardless of what brand of blade you use. The yoke passes right through the blade, the yoke hole location is the relevant thing, but you should be fine on that count.
Thicker blades will change the way the yoke interacts, which is why you get more backlash.
Blade width is specific to individual planes, and cap irons are made to match, regardless of manufacturer. So, yes, you can use a L-N cap iron on a hock blade in a Stanley plane.
