New WoodChat!
Tea Caddy design
Tea Caddy design
Tea Caddy design
Patrick Gibbons
Here is a second tea caddy I just finished. The picture shows how I incorporated the divider inside with the hinge design. This box was a bear to make. Had glue up problems, material defect problems, finishing problems, deadline problems. It's not as good as it should have been but at least it's finished.
Re: Tea Caddy design
Tea question
After a very long time away from it I am brewing tea again. Somehow tea doesn't leave me "wired" any more.
Not knowing anything about storage I presumed the dry leaves needed to be sealed until used. I presume the tea caddy is to put the dry tea in for handy on- the- table attractive storage. I like the idea. So, no problem storing tea in such a container?
David Barnett
(Message Deleted by Poster)
Favorite sources?
Wiley Horne--So. Calif.
Hi David and all,
I enjoy Chinese white tea a lot. From Mark Wendell right now, but keep thinking there may other sources to be considered.
Wiley
David Barnett
from here in the boondocks
I like Darjeeling of what ever kind I find available here in E.TN. Less fond of any Chinese I have tired. I worked with a Chinese person when I was a young tea drinker. His procedure for tea was 1/4 cup leaves to 1 cup water. They were great long leaves like a willow. Strong does not begin to describe it.
But what is "white tea"? Would an unsophisticated palette be able to tell it was different?
here is a little west coast tea importer *LINK*
Robin Corell in Atascadero CA
here is a link to a tini west coast company that imports their own teas. Ive tried their silver needle white tea and their white peony and both are very nice. A while back they also had a nice pu erh but I didn't see any listed on their web site.
Robin
Swan Sisters
Re: from here in the boondocks
Most westerners drink their tea very politly, quietly siping it. The correct way to drink tea is to slurp it, taking in a fair amount of air with each sip. If you quietly sip white tea it may seem like colored water but when it is slurped you can really appreciate the subtle flavors and floral notes that are really there and not just some packaging hype.
Robin
Re: Tea question
Patrick Gibbons
This caddy was built to house tea bags in individual paper envelopes. Traditionally tea caddies were lined with lead, and later, aluminum foil. I have seen others use common household aluminum foil but I found it too flimsy to work with. I bought some craft store aluminum foil of a heavier gauge that I plan to use on the next box. As David said below, tea needs to be closed to air and light to maintain freshness. This caddy included a lip on the top for just that reason, though I don't believe it's nearly enough. I'm evolving my design and working my way through details. It's great to have you ask the question I've been working on for the next iteration. I didn't bring it up assuming not many would care. That's why I've only used maple so far and not finished the inside. Veneered caddies were common. Loose leaf caddies usually had two containers inside the larger caddy that held green and black tea. A sugar container would also be very common.
Keep the tea recommendations coming, I'm writing..
Patrick Gibbons
...as fast as I can.
Tea caddy history *LINK*
Patrick Gibbons
Here's a good link for the curious.
http://www.hygra.com/teacaddy.htm
3 compartment tea caddy
Patrick Gibbons
The Complete Woodworker, edited by Bernard Jones, has a great plan for a three compartment caddy in a typical late 19th century, Oriental-look design. Over five years ago I drew up full-size drawings for reproducing the box but put the project on hold after an extensive, but ineffective search for an appropriate sugar bowl. I was in the gift business but still could not find a bowl that would work for me. Of course there are other solutions but that's what got me started down this path.
David Barnett
Re: Slurping, Darjeeling, and the decline of Empir
Its beginning to sound like wine. I'm thinking I would not like white tea.
CStanford
Very nice. Lots of woodworking in little box projects and can be harder than something much larger.
which illustrates.....
...the depth and breadth of interest and knowledge on this Forum is staggering. Ellis should write a book, "you wouldn't believe what I learned on the woodworking forum".
Thanks very much!
To all,
I much appreciate your suggestions, particularly David and Robin. Two of my main fuels are Dunkin Donuts coffee during the day, and white tea at night. [David, don't start with me about coffee--I've tried everything and Dunkin Donuts is my favorite. That's it. Done. But what do you think?].
I'm not a connoisseur. I drink tea in big mugs (like 15 oz) while doing other things. Make up a pot per night, and drink it. So I need to buy in half pound or pound lots. Robin, I'm much attracted to the Swan Sisters and like what they're trying to do--will keep an eye on whether they'll offer quantity pricing. David, I think I'll order a load of Upton's Moonlight White, as you did, and go from there. No complaints about Mark Wendell, either, just wondering what's on the other side of the door as usual.
Thanks again!
Wiley
Hi Bill,
White tea is mild, too mild for some folks. Makes up to a light amber to amber color. The taste puts me in the mind of thin honey. It has no bite, or tannin taste. Ever.
I don't do anything fancy. I make a pot per night. Use a No. 4 Melitta brown coffee filter to hold the tea leaves, then pour sub-boiling water right over it, into a stonewear teapot. I make up a quart or a little better at a time, and drink that through the night. The last mug is as good as the first--it doesn't develop any bite or tannin taste.
Give it a try. By the way, I've begun to use your suggestion of roasting the steel cut oats, and like it a lot!
Wiley
We had a Chinese astronomer up here...
John in NM
Couple years ago. He made tea as you describe, huge amount of leaves in a glass, add hot water, and just keep those leaves going.
He made me some, and it was definitely better than any of the green tea my wife drinks, but I didn't like it as well as black tea or best yet coffee. I couldn't get that guy to sample my coffee, he said he was afraid to try it :D
Coffee
"I couldn't get that guy to sample my coffee, he said he was afraid to try it."
Maybe he made that decision after he saw you using it as solvent to clean some of the machinery. :D
David Barnett
Re: Coffee
John in NM
I do like to pack the whole day's worth into just a couple cups :D
David Barnett
Roasting your own beans
Patrick Gibbons
Many years ago I was out of espresso beans and decided I would parch some less-roasted beans I had on hand. I placed them in the oven on low heat and was rewarded with copious amounts of smoke and a wake up call from the fire alarm. How does one go about parching your own beans and where does one obtain unroasted beans in this day and age?
Re: Two alternatives to aluminum
Patrick Gibbons
I should have guessed pewter. Zinc has a less refined look but would be interesting in some situations. I have some 18 or 20 gauge aluminum that is colored red (anodized?) that I picked up somewhere about 5 or 6 years ago. While I haven't finished the insides, shellac is food safe. I wouldn't think it would impart any taste to the tea. I am wary of using certain unfinished woods that could flavor the tea. If an unfinished wood is used with loose leaf tea, the wood would pick up the flavor of that particular tea. Any change in variety in the container would manifest contamination of taste to some extent.
