Shooting End Grain: Follow-up
Phil
In our last episode, we discussed (among other things) how thick a slice is usually taken when shooting cabinet sized component parts. I generally have the hang of it now, using a makeshift shooting board, and a LN LA Jack, with a A2 blade honed at around 32 degrees (which key is it that give you the degree sign?). I'm finding that around .002 in. slice seems to work, although considerable force has to be applied (hard to quantify that of course). I am now wondering if going to an O1 blade and honing around 22 degrees (primary bevel at 20 degrees) would make a significant/noticeable difference in the force required to get the same .002 cut? Also, knowing that I won't get as much mileage from the O1 vs. the A2, will there be any difference in cut quality? I know the theory, I'm interested in seeing if anyone has been down this road, and recommends going to the O1 blade?
