New WoodChat!
sealing end grain
sealing end grain
Jack Guzman from Maine
sealing end grain
I went to my stored supplies to see what I have to seal the end grain on some green maple blanks I need to dry. My anchorseal has hardened in the can. I found a can of some spray stuff I never knew I had. Called pruning sealer by a company named Green Thumb. Has anyone had any experience with this stuff?The instructions say it's to coat the tree where a limb has been cut off to protect it from bugs. When I spray it ,it looks and smells alot like automotive undercoating.
I can always cut off each end of the blank when I'm ready to use it.The idea is to let them dry abit without checking. The wood is juicy right now.---Jack
Re: sealing end grain
What about outdoor house paint
Probably better than undercoating
wood glue works well
A thread without body,packed with info---thanks
Few words, saves paper
Fast read ... Surplus candles
Dale Lenz
I've used everything said so far, all works
Re: I use latex exterior house paint
TomD
+1. I actually have some of the emulsified wax, and I can attest it will last for ever in storage. But I have had to make substitutions, and when that happens the best I have found is white latex paint, something with lots of solids. I normally have Behr higloss. I have used boat epoxy on the ends, and I thought that would be the very best, but when the log cracks it breaches the epoxy.
CStanford
Anchorseal. Latex paint is a joke.
Thoughts about the problem....
Water leaves end grain about 10X faster than radially. Hence, under conditions of rapid drying the ends of lumber can dry and therefore shrink, much faster than the bulk. The result will be split ends. The cure is to either retard the over all drying rate of the piece or retard the drying rate of the ends by coating them with something that retards moisture transport. The ends don't need to be sealed. The rate of moisture loss just needs to be reduced to more of less match the radial rate. Virtually anything that sticks to the end will do if it is applied before any end checking begins. Research (Wengart, VA Tech) has shown that application after checking is established has no beneficial effect.
Latex paint works but the pigments are abrasive and hell on sharp edges. "Paint" without the pigment would seem to be a better choice. While I have never tried it (I rarely ever coat ends unless it is turning squares) it would seem that a water based varnish of any sort would be a good choice,. or maybe concrete sealer, or water based deck sealer or any such "clear" sealer product.
With a lumber stack I solve this problem by simply restricting air flow across the ends of the lumber piles. This simple solution helps to match the end grain drying rate to that of the rest of the stack. This solution is effective for 4/4 lumber put on sticks in the cooler months. If the lumber is 12/4 I end coat it.
If someone tests water based sealers let us know the result.
I know all about anchorseal. I'm all out and looking for an alternative for the time being.---Jack
CStanford
Then, as somebody has already mentioned, candle wax or I would add - canning wax. You can thin it with paraffin lamp oil if you want to brush it on. Since ends are usually sacrificed you can also just paint them with epoxy glue. You can also varnish board ends - use spar varnish if you have some. A little goes a long way so this isn't an expensive alternative. Same with the epoxy if it's a metered system.
Latex paint is still barely above doing nothing.
If you need more options I'm sure I can come up with some.
Cheers.
Bags and shavings
Bob Hackett
Place them in garbage bags,keep the bags out of the sun and away from heat sources and turn the bags inside out every other day.
Too much work? Place the blanks in paper grocery or feed bags and then bury the bags in the pile wood shavings you`ve thrown into an unused corner of the shop and forget them till late spring.
Boiling the blanks helps, soaking in alcohol and then bagging in paper will greatly shorten the drying time but these techniques bring us back to the more labor intensive end of the spectrum.
I`ve also heard it said that rubbing a boiled potato into the end grain will effectively seal it. Too lazy to try this but I have at least two friends who swear by it.
Turners are masters of this stuff. If you want to be overwhelmed with info then search the archives on the turning forum here at Woodcentral.
Good luck with this Jack. If things don`t work out for you with these blanks email me and I`ll look in my dry wood stash for replacements for you.
Re: Bags and shavings
Thanks for the offer Bob but I always manage to come up with dry blanks. I'm just trying to improve my methods. I have used garbage bags before but was leery of it because of molding. I suppose opening the bags is to let out moisture? I have a dark unheated shed under my entry stairs that I use. I get tiny checks in the ends but they don't go very deep. I keep the bulk of my stock in the back of an unused pickup truck in the yard that has a cap on it. When the weather warms up these will have to be moved. I may round up some burlap and try burying some in shavings. As for the potato. I'm going to test that one. Let you know how it works in a few months.---Jack
Epoxy, PU Glue, PVA Glue, Spar Varnish
