New WoodChat!
better rule for measurements
eliot d
I'm tired of trying to read the stainless steel( or whatever they are) rules; I almost always get a glare from the lights so that I can't see the markings very well. What would you suggest for an improved one?
Re: better rule for measurements
William Duffield
Starrett makes satin chrome rules for their squares that are much easier to read under adverse lighting conditions. These are top of the line, made in the USA, very accurate, but not inexpensive. The 4R blades are graduated in 1/8, 1/16, 1/32 and 1/64 inch. The 1R blades are graduated in 1/32, 1/64, 1/50 and 1/100 inches. They also make metric ruled blades.
Here's a page from the catalog of one company that carries them.
http://www.use-enco.com/1/1/63418-50084-starrett-satin-chrome-combination-square-blades.html
You can also get them from Joel at Tools for Working Wood.
Re: Digital
TomD
Digital 24" caliper
http://www.ebay.com/itm/24-x0-0005-HEAVY-DUTY-DIGITAL-CALIPERS-WITH-FINE-ADJUSTMENT-AB11-1660-/160944749304?pt=LH_DefaultDomain_2&hash=item25790dfaf8
Range:24"/600mm;
Resolution:0.0005"/0.01mm
Resolution: 0.0005”(0.01mm).
Manual power on/off.
IN/MM conversion.
Zero setting at any point.
Data Hold Function.
Rs-232 output.
180 is a bit rich for me, so I use 6" calipers and just zero them to a shorter rule. But the reality is there are long scale read out out there for a lot less than that, and the caliper ends aren't worth much, so I imagine someone has this for like 69.
While it seems abusive in an ideal world, even a lot of metal workers, scribe the metal right off the jaws, which are hardened. So one can make an accurate measure, then mark directly to the wood like a marking gage.
George Colonel's Workshop-Havertown PA
good Afternoon Eliot,
One of the best devices I've used was a black plastic rule with white graduations. It broke. Now I use SWMBO's eyes which are just as effective, but prettyier.
George
Good to hear from you Colonel.....
roger lance
Jim in Canada was asking about you in Messages.....you might want to say hi.
John in NM
They also make flexible rules in the satin chrome finish, very handy.
And for a bench rule... *LINK*
I'd go for the thinner flexible (or even rigid) rule over a combination square rule. The thickness of the combo square rule can make precise measurements harder.
Brass City Records has some blems in Starrett satin finish rules, $10 (plus shipping). Link below. You have to scroll down past the chisels to get to the machinist's tools. And call, don't e-mail - Walt's not real good with e-mail.
I should comment, too, that I've purchased some of Walt's "blems," and danged if I can find anything on them that's less than perfect. I guess you need sharper eyes than I've got to find the blemish.
http://www.brasscityrecords.com/toolworks/new%20tools.html#Starrett_&_Machinists_Toold
incra t-rule *LINK*
Lars Parrington
yet another satin steel ruler, perhaps not what you are looking for.
but i had to mention them anyway because they are excellent for all kinds of layout work. my only complaint is that the t-track is too short on the longer versions.
http://www.amazon.com/Incra-T-RULE06-6-Inch-Precision-Marking/dp/B00004TRBW/ref=sr_1_2?ie=UTF8&qid=1357352750&sr=8-2&keywords=incra+t+rule
Wonderful tool
Re: better rule for measurements *LINK*
Bob Entwisle in NJ
These black chrome rules might be easier to read.
While I don't have the rules in the link, I do have a combination square at work from PEC and the quality is excellent.
The rule on the combo square is satin chrome, which I find very easy to read under less than ideal lighting situations.
Bob in NJ
http://www.productsengineering.com/rules/blackchromerules.html
CStanford
Now THOSE do look helpful!
Re: And for a bench rule...
Richard Jones
Bill,
Thanks for the steer to Walt, his stuff had slipped my mind. Found a couple of things I "needed" this morning.
Re: Except…
William Duffield
…Except that it's fragile.
…Except that it requires a mechanical pencil with a .5 mm lead. A striking knife, or an awl or an X-acto knife or a carpenter's pencil or a ball-point pen or a sharpie won't do.
…Except that if you are making multiple measurements to the same dimension, you have to find the same little hole for each measurement, unlike a combination square or double square, which is "set and forget".
…Except that you can't set your offset directly from a physical thickness or a physical width or a physical depth. A combination square or double square can do this, by touch, without getting out your opti-visor and work light.
…Except that the little lines every 64th are incredibly distracting when you only need to measure to a 32nd or a 16th or an 8th. With an R4 rule on a combo square, you just turn the rule over or turn it around.
…Except that you only have the choice of 64ths (granted, that's usually my first choice), but not 100ths of an inch or millimeters.
I have one of these. To insure that I still have it, and that it still works, I had to make a case for it. To use it I have to get the case out of the drawer, pull it out of the case, make the measurement, put it back in the case and put the case away. My Starrett double square, OTOH, fits in my shirt pocket or apron pocket, and if I drop it or knock it off the bench and step on it, it keeps on ticking.
I also have one of the Incra protractors. The case I built holds both the "square" and the protractor, and the mechanical pencil. I pretty sure that the old Starrett 12" three head combination square that I bought at an old tool show cost me less than the two Incra tools, and it also came with a centering head and saddle square. A hundred years from now (assuming no apocalyptic event occurs in the meantime), it will probably be just as accurate as the day the original machinist bought it.
Re: incra t-rule *LINK*
Lars Parrington
William, you critiqued this ruler above, i think you must have intended to post here, so i am replying here.
-- "…Except that it's fragile."
how so? i didn't make a case for mine. i abuse it, sometimes bend it intentionally to clear obstacles. i wouldn't gasp if it dropped on the floor.
-- "…Except that it requires a mechanical pencil with a .5 mm lead..."
true. actually incra claims you can use an awl with it, but i never have. some accuracy is lost due the width of the pencil line. the lead doesn't last long, i often need to advance the pencil mid measurement.
-- "…making multiple measurements...you have to find the same little hole for each..."
yep. i usually don't find this to be a hassle. although sometimes i will make a pencil mark on the ruler next the the hole to make it that much easier.
--"…Except that you can't set your offset directly from a physical thickness..."
no, but you can measure the thickness with the ruler, and then mark at that measurement.
--"…Except that the little lines every 64th are incredibly distracting..."
actually most of the scales only have lines every 32nd or 16th.
--"…Except...only...64ths..., but not 100ths of an inch or millimeters."
they sell a "pro" version for a few $$ more that has 100ths and millimeters.
now i'm not trying to say this is the ideal ruler for every task. i just find it incredibly handy for certain tasks. the best example i have is doing layout for chipcarving, which is essentially drawing graph paper onto your piece of wood. i also used when making my shoe rack (see link below), to layout the locations of the 24 wedged through mortises per side panel, on both sides of each panel.
shoe rack project
Re: incra t-rule
William Duffield
Oops, I wonder how I got the post in the wrong place? Yes, I meant to post it in response to your and Ron's recommendations. Regarding fragility, It seems fragile when I use mine, so I've always been very careful with it. It's good to know it's sturdier than it appears. I'm not saying it is a bad tool. It has its good points. I just find that a good machinist's combination square works better for my needs.
And, yes, the rules for other scales for machinist's squares also cost extra.
I'm not saying "Don't buy it." It is a good tool, and very precise. Just know that it has some limitations and some disadvantages, and for many people, a good combination square might serve their needs better.
I understand
Ron Harper
I do not use it unless I must be very, very persnickety. I am learning from my studies with Paul Sellers to measure as seldom as possible. I now mark as much from the work in progress as I can. I.e. if I have 4 stiles, I will measure once and mark the others from that one. I have a little 4 inch combination square that someone would have to pry from my cold dead fingers.
Re: I understand
TomD
I hear you. The problem with combination squares is that at this time of year, I think I know how the fingers got cold and dead...
Re: I understand
William Duffield
Sometimes, the old ways have advantages, too. This morning, there's frost on the ground, and the wooden try square and a boxwood four-fold rule would have some advantages.
The Incra has a much lower specific heat that the combo squares.
Keeping the 4" double square in my breast pocket keeps it warm.
…more reasons to not try to pare your tool kit down to the bare minimum.
