New WoodChat!
Kerfing saw??
Kerfing saw??
Kerfing saw??
Ron Harper
Anybody seen or used one of these.?
I am envisioning something like an adjustable fenced woodie with a rip saw blade for a cutter. Seems like it would be a tremendous aid in resawing. You could establish a kerf on the edges and ends for the saw to track in
Ron in Kokomo
Re: Kerfing saw??
Re: Kerfing saw??
Lars Parrington
neat idea, never heard of one. sounds kind of like a plow plane with a 0.040" iron. or maybe a marking gauge with a little chisel for a cutter.
Re: Kerfing saw??
Re: Kerfing saw??
Kees
Something like that is in the catalog from Wertheim, a plane maker in Austria. He was (one of) the first with a detailed illustrated catalog. You can find it here:
http://pudl.princeton.edu/objects/qr46r156v
Find volume 2 and look for nr. 117.
Re: Kerfing saw??
Re: Kerfing saw?? My misfortune
TomD
has been that the saws I use are good enough, and sharp enough that if they are prone to wander they will cut right into the side of any kerf. It is easy enough to get saws that sharp. But getting saws that are perfectly balanced so they fall straight down in the cut, is a lot more difficult. If I had a saw that was dull enough to bounce off the kerf, I would probably prefer not to use it. I gather that others do not have this problem, but I do.
I would prefer to know what saw Wiley was using to cut those veneers, on his Flickr page.
Re: Kerfing saw??
Re:WoW That was fun getting to 117
Re: Kerfing saw??
Re: Kerfing saw??
AlanWS
It's an interesting idea. The closest thing I've encountered is the cutting gauge Steve Latta uses to excavate a space for string inlay. (See Woodwright's shop episode 3109) His cutter is essentially two teeth of a crosscut saw, because he is interested in tight curves, so a saw with more teeth could be a problem.
The easiest way to try out your idea might be to get a Stanley 45 and make yourself a blade to replace the slitting cutter. You could file and set a few teeth in a piece of saw plate, and mount it into the plane for a test. Incidentally, a 45 without many cutters can be very inexpensive.
Re: Kerfing saw??
No
Ron Harper
It is like a moving filletster plane with a small rip tooth saw blade as the cutter
Re: Kerfing saw??
Re: Kerfing saw vision real?
Bruce McCrory
Is your envisioned saw something that was real?
I hear a good cutting gauge with a deep cut will guide saws. Older, high quality Disstons and etc. had filed plates (for kerf-type cuts).
I use pull saws, with thinner blades than western style push saws; finely kerfed. Western saws are pretty sloppy with big kerfs compared to plate thickness.
There are a lot of ways to skin the wood.
Re: Kerfing saw??
Real
Ron Harper
Bruce.
Several guys from the Porch have sent me copies of patent apps. They look like moving filletster planes with a saw blade for the cutter. I understand that Tom Fidgen has dedicated a chapter of hi new book to this wonderful thing.
Re: Kerfing saw??
Re: Real
TomD
That is a whole other thing. I was thinking of making something like the Bridge city table saw thing, but with a blade in a wooden handle, so if you want a precise cut you could just jig it and make a cut. With the ramped blade, so it only takes one stroke. Fretting being one use. But not so I could kerf a saw blade to not wander.
Re: Kerfing saw??
Re: Real
TomD
Well because he expects it to guide his saw in deeper cuts. In my case I didn't find that effective enough to be worth the effort, just a relatively small amount of practice proved a lot more useful in my case. But even where that is the case, sometimes having the surface cuts squared out is all you need. And then there are cases where the final product is just a kerf. Like frets, or linings.
Speaking of which, I love looking at this:
https://www.youtube.com/watch?v=h-pdUWoNjPo
Re: Kerfing saw??
Great video
jack curtis
Only thing more fun to watch than the demo for the Bridge City Jointmaker.
Re: Kerfing saw??
I thought it was pretty nifty, too,
Bruce, a MN Galoot
but I was left wondering how much bent stuff I'd need to make to justify inventing that kind of contraption. I do have to marvel at his ingenuity, in particular the self-advancing mechanism.
Re: Kerfing saw??
Re: I thought it was pretty nifty, too,
TomD
There are some folks whose brain seizes after the second kerf. There is like 10-12 feet of the stuff in each guitar. Some folks make two guitars a week, in small shops. That would be 600+ kerfs a week. Boring. I think Keith has a background in machine design or something related, so he probably couldn't stop from visualizing a solution.
Re: Kerfing saw??
Re: homemade jointmaster
TomD
OK, single purpose. But it could be used for stuff like making tenon shoulders.
https://www.youtube.com/watch?v=m44jBZeS1QM&playnext=1&list=PLE9D67872B160A514&feature=results_video
My thought was to make a wooden saw with a blade inset at a cutting angle, then rather than having to make a whole sled deal, I could just run the saw, like a stair saw, against a fence.
Re: Kerfing saw??
It's a mind numbing job.
Re: Kerfing saw??
I hadn't considered guitars or their ilk
Bruce, a MN Galoot
I've only made one dulcimer, so I didn't find the kerfing business to be onerous. I just set a stop on the bandsaw table and wasn't terribly precise about the spacing of the cuts. If there were more in my future, that operation could definitely become problematic.
Re: Kerfing saw??
jack curtis
I've thought about making my own jointmaster, too, a lot. So far the best I've come up with is an old contractor saw chassis with an upside down Japanese saw instead of a circular blade. It would provide everything.
Re: Kerfing saw??
Roubo
Wiley Horne--So. Calif.
Great post, Jeff! Thanks for the information.
Demonstrates in an anecdotal way how little new-under-the-sun there can be in hand tools or mechanical operations in general. It's a tribute to Ron that he reinvented the 17-18th century.
Isn't someone (Lost Art Press maybe) working on a Roubo translation and reissue?
Wiley
Re: Kerfing saw??
Re: Roubo
TomD
Yeah, if we can think of it, it already exists. Isn't that the lesson from Williamsburg and elsewhere. They would ask the Blacksmiths to make some novel tool to do something they figured a specialized tool could do more easily, and then latter research would turn up the tool. Even with google, we often don't know what to look for until we have invented it in our mind, and then it turns up everywhere.
