New WoodChat!
REAL MILK PAINT
Hand tool to the Rescue
Kevin French
So at today we're putting in some shelving in new (to us) Postal trucks. I was building the shelves and the other Maint. guy finished his work and decided he would install some before the carriers left for their routes. Of course we have only one screw gun and his installation was more important then my building more shelves so he took the gun.
I wanted to finish the two remaining shelves and move on wen I remembered I bought an old Consolidated Tool Works Breast drill a couple day before and it was in my car. It wouldn't hold the 1/8" twist bit tight so I put the screw driver bit in it and it worked great. 2 1/2" Sheetrock screws, no pilot hole, beeswaxed, straight in, no effort, lots of torque, no slip.
Looks like I'll leave one in the shop set up that way.
The Consolidated Tool Works Breast drill didn't have the best fit and finish some of the other companies had. The outer gear ring show signs of warping, the pin that retains that gear slipped when the drill was set up to use the outer gear and a lot of the chrome was loose. But for $5 it was worth the lesson.
Re: Hand tool to the Rescue
Huh!
I've never tried a breast drill for screwdriving - I've tended toward a brace. Thanks for posting...I will have to try that. If it works, I've got a justification for the several breast drills that have, somehow, migrated into the shop.
BillTindall
A brace is an excellent way to drive square drive screws, or undrive them when they are stuck(rusted like in the sheep pens)
George Allchin in Lowell, Mich.
In my trade (tool and die) everyone has a pneaumatic hand grinder so when a friend sold me some of his Grandfathers tools including a crank bench grinder, I had to take it to work.
I would say "Hey Jerry, look at the hand grinder that I just bought!". This was sure to get a laugh out of them and a little hand tool education. The grinder is now set up in my basement clamped to my third workbench. The other one is out in my wood workshop.
Back to the screws though. I like square drive for the hidden screws. I have 4 Yankee push screwdrivers with magnetic bit holders with square bits in them. They don't have the torque that your breast drill or brace would have. Now I also can also further justify the group of braces and hand drills that I own.
Thanks Kevin.
Work safe,
George
Jack Guzman from Maine
Recently I was with a fellow carpenter and had a large slotted screw that had to be removed. Previous attempts with a handheld screwdriver slipped for lack of a good bite.I took down a brace I keep with a sharp slotted bit and leaning into it the screw backed right out easy as can be.---Jack
Getting a grip on slippery screws
Bob Hackett
One trick that has come in handy for me when backing out damaged screws (or to keep from damaging them) is to wipe a little valve grinding compound onto the tip of the driver. It`s amazing how much extra grip a simple thing like this can give you.
In a pinch (and when I can`t find the valve grinding compound) I have used slurry off a water stone to good effect as well.
I am finding that I also use my breast drill and my short throw brace a lot more than my cordless drill now. They both keep working long after both batteries on the cordless have been depleted. The charging time is also far less. :D
TomD
I use my brace for setting drywall screws. If something happened to cause the screw heads not to sit lower than the surface level, I set them with the brace because one has tremendous control. Usually the problem is something like the screw went in at an angle. In that case it is all too easy to set the screw so low that it tears the surface paper. With the brace one can set the screws to the perfect height, if the drywall screw gun failed to do so.
