New WoodChat!
Off topic - losing a fingernail
After bashing my right index finger twice in succession (hammer and hammer stapler, fortunately missing the finger with the actual staple) a couple of months ago, I've been sporting a black fingernail. It's now, finally, coming loose as the new fingernail grows in. Presently, it's loose at the back and most of one side, and ready to catch on things. The last 1/4" or so at the tip is still in contact with/bonded with the skin (not sure if it actually bonds) I'm keeping it covered with a bandaid, so I don't tear it off unintentionally.
But I'm wondering: is the nail bonded to the skin where it appears to be? Will just yanking it off cause a lot of blood and/or pain, neither of which would be much fun? That is, do I just keep on covering it until it comes off on its own?
Re: Off topic - losing a fingernail
david weaver
Can you cut and sand off the part that's not bonded and then just sand whatever's left so that there's nothing that can catch on things?
That would currently be pretty awkward. I guess I'll just keep a bandage* on it until it's closer to ready to remove.
*Yes, yes, I know I should use duct tape; but bandaids leave less residual adhesive. Plus, you can get them in superhero designs, although I don't currently have any like that.
dang!
Bill Tindall
I caused me pain reading about it. No pictures please!
Re: dang!
Philip Duffy
Bill, here is what you should do The Next Time. Put a 1/16in drill bit in your drill press, turn the speed down to low, put your finger on a block of wood and bring the bit down to where it just touches the nail and lock it down. Then,(this is the hard part) turn on the drill press and breath normally. Before long you will relax a bit, the finger nail will rise slightly and the bit will drill a nice little hole in the nail, blood will flow out, and you will be cured!! It works for me, but then, I am a Naval Aviator and helicopter pilot and we all know how crazy we are!! Philip
Re:no dri** press!!!!
George Allchin in Lowell, Mich.
I did that once and it went too far!!!!!!!!
Get a sharp pointed knife and use the very tip as a drill as you slowly twist it back and forth.
My doctor told me once to heat up a straightened paper clip red hot and melt/burn through the nail to relieve the pressure.
Work safe,
George
Drilled a hole once
I just used a sewing needle heated up red-hot. Burned right through, and relieved the pressure. Seems safer, and more sanitary, to me than a drill press. Grossed my family out, but, as I pointed out at the time (and in conversations since when I mentioned it), there are no nerve endings in the fingernail itself. I've got a pretty low pain threshold, and wouldn't have tackled anything that might lead to whimpering sounds coming from me.
I still lost that nail, though. I think if you damage the connection to the nailbed, the body rejects the nail and grows a new one.
Sorry, Bill T. At least I didn't take a picture of the process.
It works
Bill Tindall
Years ago I rolled a rock on my finger. Woke up in middle of the night in agony. Told wife I needed to go to emergency room which was alarming because she had never seen me get near a doctor. The emergency room was the teaching hospital at University of MN. Somebody as young as I showed up and told me to sit. he returned with forceps, alcohol lamp and a paper clip. Yikes, I thought, this is a quack! But my arm hurt so bad I was willing to risk what ever he had in mind.
As you described, he heated the paper clip to red heat and slowly burned a hole in my nail. The tiniest drop of blood came out and pain drained from my arm as if by a miracle. I think mashing ones finger in a clamp might be more effective than water boarding if this experience was any indication.
Re: It works
I don't know what the concentration of nerve endings is in our fingers, but it's pretty high. Useful for safe crackers, and, of course, other fine-motor-skilled work; but hell on wheels when we mash them.
David Barnett
(Message Deleted by Poster)
Always educational, you are, David
Re: "Pilliwinks" - This Auld Handtool
TomD
And at the time they thought those things were high tech. Apparently the idea of a screw was at one time incomprehensiblye techno, like say those rays that cause people to stop rioting.
I once saw my wife reaching up to a shelf while standing on the side of of a cardboard carton. All the more surprising, and she does stuff like that every day, today it was the water bottle, because she once reached to a high shelf and then as she stepped back down, caught her ring on a shelf and tore her finger off. They managed to re-attach it, but it does not work entirely properly, though it looks normal. So you know, there are degrees...
Marhk
In general the treatment would at this stage to keep the area clean with soap and water. Keep the nail covered so it doesn't snag on anything. It will fall off naturally. It can be removed but removing it prematurely leaves a nail bed exposed that is liable to bleeding and pain. The nail needs 6-7 months to fully regrow assuming there has been no injury to the nail plate at the base of the nail - unlikely, in general. Now as to the trephine procedure - hot paperclip trick or gentle twisting of a sterilized knife tip: This is useful soon (within 24 hr or so) after an injury to let the blood collection out from under the nail and relieve the pressure. This greatly helps the pain and may prevent loss of the nail. Risk is minimal but includes introduction of infection. (Remember you need to have up to date tetanus immunization) This is of no use now, several months later.
Oooh!  Squirming around in sympathetic pain
"...because she once reached to a high shelf and then as she stepped back down, caught her ring on a shelf and tore her finger off."
This is why I wear my wedding ring only when we're going out in a public setting where I won't be doing anything that looks like physical work.
Pah!!
Bruce, a MN Galoot
True story:
My secretary's husband worked at an oil refinery. He told the story of a worker who was sprayed with concentrated hydrofluoric acid, some of the nastiest stuff on the planet. For the most part his suit protected him, but some got underneath his gloves. He was able to neutralize the majority but some had gotten underneath his fingernails. and he was in absolute agony. The problem is that HF keeps dissolving everything in its path until it reaches calcium, in this case the bones of his fingers. He was brought to the hospital emergency room where every effort to neutralize the acid failed.
He begged the doctors to rip out his fingernails, which they did, that being the only thing that would let them get at the remainder of the acid.
I told that story to a bunch of classmates in refinery school and it was confirmed by the son of the man who suffered that accident.
wilbur
Leave the nail on. Don't rip it off. Let it come off on its own. Hello Kitty bandaids are the best.
This is a considered medical opinion.
WoW!
I forgot about the Hello Kitty bandaids.......
I've used all kinds but you are right they were particularly effective!!!!
Work safe,
George
Jack Guzman from Maine
Leave it on. It will create a new injury if you rip it off. I've been there. Been aiming a hammer at my thumb and mostly missing for 30 years now as a carpenter. If you can get at it try to clip off as much of the loose nail as you can but if not nature will get rid of it quick enough.---Jack
looks to be an opportunity
Bill Tindall
make her a step stool for Christmas.
Bandaids
If I could find Mighty Mouse or Darkwing Duck bandaids, I'd spend the extra money. But, alas, the makers of bandages go for more common cartoon figures.
Bruce McCrory
I am partial to masking tape ... Yellow, cream. The blue starts unreeling too quickly. The folks in UK have a perfect M-tape. It's very similar to the non-woven stuff common in emergency rooms that imparts a gooey mess requiring lighter fluid and sandpaper to remove. But the UK tape has good adhesive.
I should order some and take it with on my next trip to ER.
Re: What me? Drop another great big piece of coal.
TomD
on my toe, you must be... OH!! I just dropped another great big piece of coal on my toe, I have...
As in the classic piece about the difficulties of mining in Beyond the Fringe... My daughter had something fall on her toe last summer, at the beach, and nobody paid it much mind, and we have been arguing since about whether it was all going to come right, or just required a little scraping. So off to the surgeon this morning, apparently she broke her toe, and they were sawing away at it, wife passes out, which is odd because she is tough and practical. Sounds like quite the happening. Reducing this to terms of self-interest I can understand, I guess if in the future I am in an accident and there is a tsunami of blood, I better not count on anyone but myself to take the pictures for the album.
One of my favourite accident stories comes from one of the bowhunting magazines. A guy was hunting with his buddy, the trauma surgeon (note to self...). He trips and as he stumbles forward he dumps the contents of his back quiver on the trail ahead, and in his attempt to stay upright, stumbles right through a broadhead tipped arrow, now on the ground ahead of him. As a result, he punctures his leg with the arrow, and starts to bleed out at a rate that is almost sufficient to kill him, though he travels with his own personal trauma dude. He barely survives. Always impressed me as to how lethal sharp edges are and how quickly a safe situation can turn around.
Karma for bad puns
There's such a thing as a good pun?
Silent ones?
