New WoodChat!
What's He Building in There?
William Duffield
I've been away for a week, just returned from DC, and put finishing touches on a small project, but too late to respond to Bill's "feature" without it getting lost off the bottom of y'all's screens.
Here's a collection of some of my favorite tools for joinery. Some I've bought new, some I've made, some I've inherited, modified or restored. It seems they have been scattered in many drawers and shelves around the shop, and often rolling around on top of benches, or stuck in dog holes, from whence they often need to be put away so I can use the work surfaces for something else. It would be better if they were consolidated, in one place on top of the bench when I was using them, and in one place on a shelf when I wasn't, and could be picked up and moved alltogether.
To this end, I've thrown together a tool rack from some scraps of wood: walnut (mostly sapwood ane wane), mahogany (squirrelly), red oak, tulip poplar and small pieces of beech. Finish is brushed-on shellac (SealCoat and Behcol, about half and half).
Filled with measuring, marking and cutting tools.
Back up on the shelf.
Re: What's He Building in There?
Very nice, Mr. Duffield!
Jack Guzman from Maine
Inspirational
Does this collectiion
Bruce, a MN Galoot
pretty much amount to most of the tools you need for a typical project? I've been thinking about a portable toolbox that I can take to my night shift job that is easy to cart around yet fairly complete. Just curious.
question
Bill Tindall
picture one: what is the silver thing top row to left of combination square right of dividers, and the two silver things extreme left?
Re: Does this collectiion
Bill Tindall
answering for myself.....yes except for a pencil and tape ruler.
A guess
Ron Harper
Router plane cutters
Really interesting idea.
Oops
Ron Harper
Just expanded the pic. I was wrong,
Guess 2....
roger lance
The two items on the left are C Becksvort/Lie-Nielsen lock mortice chisels.
Re: question
Jim Toews
The silver thing next to the square is a double-ended marking gauge, the two tools at the left are lock mortice chisels. At least that is what they look like to my aging eyes.
Re: Guess 2....
William Duffield
Yup.
http://www.lie-nielsen.com/catalog.php?sku=1-DLC
Chris Becksvoort also has a video demonstrating their use.
http://www.youtube.com/watch?v=AtT-7tA9W9I
They also work great for scraping glue out of inside corners of boxes, especially deep ones.
Re: question
William Duffield
Yup and yup. Here's the marking gauge.
http://www.leevalley.com/US/Wood/page.aspx?p=64313&cat=1,42936
I provided a link to the drawer lock chisels in another post.
William Duffield
No, not by a long shot. For starters, there are no saws, no drills, no planes, no scrapers, and no clamps shown. I do cabriolet legs and other Queen Anne and Chippendale details, so I also need rasps and/or spoke shaves. Sometimes I do a bit of carving, so I need a set of carving gouges.
I have another portable rack that I use mostly for rasps and files, a dovetail saw and some scrapers. I'll have to get pictures of it and its three mounting options.
The spartan version
Bill Tindall
Some version of these holders can be handy for wrangling the chisels and marking knives on the bench. I built it shortly after the second chisel rolled off onto the floor. I have a shelf directly behind the bench for the rest of the lay out stuff.
Trivial to make. Lay the chisels on a board. Trace the outlines. Make a dado defined by these lines for each position by the method of choice. Glue a thin strip over the dadoes to form the rectangular opening to accommodate the chisel. The legs are M&T into this part and a base. A leather strip makes a handy knife holster. I was forever loosing the marking knives until I made a fixed place to return them too.
When I have needed chisels in another location, demo or class, I just plop the whole affair into a box and carry it off. I don't recall I have ever been complimented on the quality of construction.
Ron Harper
While i kinda like it, i have to think about it some. If accessible tool storage is close to the bench, it seems like an extravagant use of bench top space?
William Duffield
One size does not fit all. Back when I was inexperienced, I built several jigs and fixtures out of magazines that "seemed like a good idea at the time," and then I found out that they just didn't fit my way of working or my way of thinking or the projects I wanted to build, so they just collect dust and take up drawer space.
Parts of this rack sat on the shelf for several months, dry fit, unfinished, and holding a subset of the tools that are in it now, before I decided I had to refine it, fit some more tools in it, glue it together, add the feet, and finish it.
You could set yours in your tool tray :D . I might set mine on my jointer infeed table or radial arm saw table, which are closer to the bench than the shelf it sits on when I'm not using it. Often, I have to move several of these tools off of the RAS when I need to cut a board to length, so using the rack should save me a bit of time. It might even fit on top of my bench, under my meta-bench, but I think the feet I put on it so I can get my fingers under it made it a bit too tall. Note that the chisels can be removed and replaced by lifting them about an inch, but without lifting them all the way clear of the top of the rack.
Now, I need to train myself to put the tools back in the rack instead of dropping them on the bench when I'm done with them.
why the space is worth it
Bill Tindall
Basically the rack holds the layout tools and chisels for making a carcass and drawers. These tools are used repeatedly in the course of case and drawer construction. If they are not within arms reach in storage they will get put and left on the bench surface anyway, where they become mingled among the parts under construction. What I find nice about a rack is that it motivates me to return the tool to its place on the rack where it is readily found when it is needed again.
Bottom line: If you are often searching for these small tools mingled among furniture parts on the bench some sort of rack holder may be beneficial. The guiding principal should be to build the rack to accommodate that which would otherwise occupy the bench surface However, if all these small tools conveniently shuttle back and forth between some other form of storage and the bench, bench rack storage would offer no advantage.
If you travel, the case for the rack becomes even more compelling.
Personally, William's rack holds more stuff than I would find necessary to keep on the bench. However, I intend to add marking gauge and 4" square storage to my spartan version. These two tools stay on the bench and are often lost among the parts.
Re: Another Version for Rude Mechanicks
William Duffield
I've had this one for several years, and have modified and repaired it several times. Mostly it now holds rasps and files. Like yours, it is formed from dados in a core board. Trying to fit fat rasps into thin holes has necessitated enlarging the holes and reattaching the 1/8" okume plywood faces with FHWSs. (Oak is a lot sturdier.)
Instead of a flat base, it may be attached to various stands with a cleat on the back.
I have a stand attached to the wall.
Another that I can stand on a bench or other flat surface.
And I can hang the rack from the edge of a tool tote.
Gonna sneak up on it
Ron Harper
I will cobble together a mock-up and see how it works for me. William, I too have had the "oh that looks cool let's build one" disease. I am not completely over it. Came very close to building a Roubo. Which I certainly do not need. You would think I would not be as susceptible to the "next big thing"
Ron
Is that a...
Wiley Horne--So. Calif.
cutting gauge there in the left foreground? If so, one of the most valuable players IMO!
Terrific piece of organization overall! Thanks for sharing,
Wiley
Re: Is that a...
William Duffield
Yup. Homemade, too. If one has a copy of the Badger Pond Archives, one might be able to find a description of it, with more detailed photos. I built it around the turn of the century. Following are extracted text and pics from that post.
Cutting gauges are most often used for marking the shoulders of tenons. The tenons are then cut with a couple of back saws, and trimmed with a shoulder plane. A cutting gauge can also be used for laying out the ends of dovetails, and even for cutting very small rabbets. They can also be used for marking the field of raised panels, although a panel gauge is typically used for this purpose.
The curved side of the fence without the knob goes in the palm of the hand. The index finger and thumb lightly pinch the sides of the bar on the cutter side. Once you set it down on the stock, these two will be used mostly to gauge the angle and depth of the cutter. The bird finger goes straight down the back side of the fence and pushes the gauge towards you. The ring finger and pinkie wrap around the far end of the bar, and provide sideways pressure to keep the fence against the end of the stock. You set the stock down on the bench with the end you want to mark hanging over the edge and hold it down with the other hand. Set the gauge down with the knife at the far edge of the stock and pull the gauge towards you. Practice on some scrap, until you get a feeling for how to do it.
Since the cutting gauge is usually used to mark the material between the blade and the fence that will be cut away, the bevel should be towards the fence. Thus it will cleanly cut the shoulder, and only crush and tear the fibers on the waste side of the mark.
You should be able to assemble one in a weekend from these instructions and dimensions. Of course, everything is flexible. Choose wood you like and shape yours to fit your hand. The durability of the brass wear strips are important for the long term smooth operation of this tool.
The beam is purpleheart, 3/4" x 3/4" x 7-1/2" with a 5/16" x 5/16" wide through mortise about 5/8" from one end. The mortise was cut with a 1/4” Forstner bit and squared up with a bench chisel. The face of the mortise towards the end of the beam is tapered to match the taper of the wedge that holds the cutter in place, about 1:10. The mortise is about 1/4" long at the bottom and 5/16" long at the top.
The wedge is bubinga, cut with a scroll saw from 1/4” stock. It is about 1-3/8" long. I put a notch in it, and rounded the head. I made the cutter from a worn out metal-cutting reciprocating saw (light saber) blade. I scored it with a file, bent and broke it to size, scraped off the paint, shaped the edge with a file and sharpened it on an Arkansas stone. It has two bevels on the same face, so it will cut in either direction. The other face is flat.
The beam has an inlaid 5/16" wide brass wear strip against which the locking bolt acts. The brass is probably about 1/16" thick. I cut the channel with a routah, but a scratch stock or beading tool (#66) or #71 router would work as well. I faired the round end of the channel with a carving gouge. I cut the brass out of a larger 3/32" thick plate (available in small quantities but at high prices at hobby shops) with a scroll saw on slow speed. I filed it to width and filed the end round to get an exact fit to the end of the channel. It would have been quicker to run the brass all the way to the end of the beam, but the piece of brass I had wasn't long enough. I glued it in place with 5-minute epoxy and filed the end flush with the inside face of the cutter mortise. I then filed and sanded the surface of the brass flush with the beam and polished it with sand paper on glass. I used 100 through 1000 grits.
The fence is white oak, 2-1/4" x 3-5/8" x 1-1/8". The ends have a 1-3/4" radius. The 13/16" x 13/16" through mortise is centered on the face. I cut it with a 3/4” Forstner bit and squared it up with a bench chisel. In one end I installed a 1/4" coarse thread threaded insert. Since I don’t have the requisite 15/32" drill bit, I drilled the hole a little large (1/2") and 5/8" deep. Before epoxying the threaded insert in place, I drilled a 1/4" hole on the same center through to the mortise. I hid the threaded insert beneath a 3/4" diameter bubinga inlay that I super-glued in place and filed and sanded flush with the oak. After the epoxy and cyanoacrylate, it is usually necessary to clean out the threads. I use a dental pick. I used the same techniques for the inlaid brass wear strips on the fence as for the brass in the beam, except I didn’t need a stopped rabbet. I cut the brass strips extra long and filed off the protruding ends after installation but before sanding them flush with the face.
I chamfered all the edges of the fence and beam, except the edges of the working faces with the wear strips, and knocked down all the corners.
I turned the locking bolt knob from cocobolo. First, I drilled a 1/4" diameter x 5/8" deep hole in a piece of scrap. I chose to orient the grain perpendicular to the bolt (like you would turn a bowl, not a spindle). Grain direction, types of wood used, and the shape and size of the knob are matter of taste and aesthetics. I turned it between centers, with a Jacobs chuck holding a 1/4" dowel in the headstock and a ball bearing live center in the tail stock. The finished size is 1" long x 1" diameter. Make sure the diameter of the knob is less than the thickness of the fence. I made the locking bolt from a long brass T-bolt (available at the Borg in the plumbing section). I cut off the head and held the waste end in the Jacobs chuck in the lathe while I removed the threads from the last 3/4” with a file. I also smoothed its end so it would not gouge the wear strip in the beam. I epoxied the bolt into the knob. Removing the excess threads has several important advantages. It means you do not have to be so accurate in drilling the 1/4" hole below the threaded insert. It facilitates installing and extracting the locking bolt.
When you need to remove the cutter to adjust its height, sharpen it or turn it around, the locking bolt serves as an extraction tool: Remove the bolt. Lay the fence on the bench. Lay the beam on the fence, brass strips up, with the head of the wedge in the mortise. Put the end of the bolt on the bottom of the wedge and tap the knob. You don’t get stabbed, and the small wedge and cutter don’t get lost, as they are “fenced in”.
To color the oak, I wiped on some ammonia (regular strength from the grocery store) and sanded off the raised grain with 320 paper after it dried. I finished all the wooden parts with boiled linseed oil and one coat of 1-1/2# cut blond shellac, rubbed out with 0000 steel wool. A lacquer would probably work better to keep the brass from tarnishing. The steel wool took the shellac right off the polished brass. I’ll probably brush on a couple more coats of shellac.
