New WoodChat!
File sharpening
File sharpening
File sharpening
Bruce, a MN Galoot
After seeing a video posted on the Oldtools list I've decided to give file sharpening a try. There is a batch of old files and rasps I scavenged from my grandfathers garage, dating back a minimum of fifty years (I should not be able to remember that far). In particular there is one old rasp that I wonder whether it can be resurrected. There are visible flats on the teeth, and I need to know if this means they are worn beyond recovery. Does anyone know?
Re: File sharpening
Re: File sharpening
Robin Corell in Atascadero CA
If it has noticabe flats on the teeth then it isn't very usable as is so what do yu have to loose? It will work but to get rid of the flats you may end up with the teeth much smaller than on a similar rasp without flats. Don't know if your instructions mention it but you need to degrease the files before the acid dip and Lye works great for that.
Robin
Re: File sharpening
Jack Guzman from Maine
Re: File sharpening
A friend recently took some of my really useless files ,including a hand cut patternmakers rasp that had alot of flats and had them "sharpened". The rasp is quite functional. I was really surprised. It's not as good as new but it resurrected what had become a useless piece of steel. It is worth the effort.---Jack
Re: File sharpening
Re: File sharpening
Chuck Bjorgen
Hey Bruce, I also have a number of old files that I inherited from my father-in-law that I believe need work and I have wondered how to do this. Would you mind posting the procedures and materials needed? Thanks.
Re: File sharpening
Not the route I took
Bill Tindall
As cheap as I am I chose to send my files to a sharpening company. The cost was but a small fraction of a new file. They were sent uselessly dull and came back as good or better than new.
Re: File sharpening
Re: Not the route I took
What process did they use and did it change the size or the teeth. I don't like how the acid method changes the teeth but didn't know there might be other options.
Robin
Re: File sharpening
answers
Bill Tindall
The company I used would not divulge the process. I expect it is some sort of electrochemical process. I did not see a change in tooth size. This company got started doing Farrier rasps. They told me that a file could be sharpened about 3 times.
Re: File sharpening
Peter Evans
Well worn rasps come up very well after acid dipping. You will find the rasp is now somewhat less aggresive than the rasp when new - but still sharp enough to use. And less aggresive rasps are expensive, the dipped rasps is not as good as a Liogier rasp, but servicable and somewhat less costly. Remember to check the files/rasps frequently and take them out when they are sharp (enough). Leaving them in for long periods does not make them sharper, but does eat away more steel and leave a hard to remove deposit on the steel.
Re: File sharpening
Re: Here ya go
Chuck Bjorgen
Thanks, Bruce. However after looking over the prices from Boggs, I might just decide to go that route. Now that winter has arrived in our state I don't think I want to mess with acid chemicals at this time of the year. If you do this, please let us know the results.
Re: File sharpening
craigd
Re: Here ya go
craigd
You can also use mild/weak acids, I use rotgut white vinegar and soak for a day or two. Many people use a citric acid mixed from powder. I've even hear a rumor that Mike Wenzloff stores his rasps in a jar of citric acid solution.
