New WoodChat!
A55 Smoothing Plane
Cradle dovetails
Cradle dovetails
Cradle dovetails
Ron Harper
Can anybody point me to a good article that shows how to layout splayed dovetails for a cradle? I would be grateful.
Re: Cradle dovetails
roger lance
Ron.....note the cradle I made with splayed sides using finger joints....the work pieces were first cut with 5 degree sides.....then fingers were cut with no adjustment on these sloped sides.....the sides were then dry fitted and cut to final height. I suggest that you do an experiment with two pieces of scrap....cut them to your intended splay angle....then cut through dovetails (pins and tails) and see how they go together.
My guess is that it will work.
Clarify please
Ron Harper
Box joints cut with no adjustment?
Re: Clarify please
roger lance
Ron....if you can zoom in on the box joints, you will see that the fingers are square to the edge of the board and not square to the board's length....if you do a little experimenting, I believe you can do the same with dovetails without getting into some very complicated geometry....try it on some scrap....with the sides splayed at a relatively small angle (I used 5 degrees....you use what you want), the grain in the fingers (or pins) will not be that compromised and your joint should work....in other words, this is not as difficult as you might think....a few minutes in the shop tomorrow and you will know.
Warren in Lancaster, PA
I used to do a lot of this kind of work when I was starting out. The end grain surfaces are a little peculiar. In addition to being skewed 5 or 10 degrees from the long edges, these end grain surfaces are also not quite square to the face of the board.
A dovetail marker will not work well for marking out the tails. Say you have a 10 degree slant to the sides and you usually mark your dovetail 8 degrees or so from the edge. If you use 8 degrees on the cradle, you end up with a dovetail that has a lot of short grain on one side and little short grain on the other. So instead on an 8 degree slant to the dovetail we might use 18 on one side of the dovetail and 2 degrees on the other. This is stronger and looks a lot better also.
I used to calculate all the angles with trigonometry, but Bill Pavlik at Williamsburg came up with a method which is more the way an 18th century cabinetmaker would think. He made a large block from a 3X3 or 2X4 and sloped the end and one side like he wanted the cradle and was able to set his bevel gauge from this block.
Thanks Roger
Tony - Memphis
Fine Woodworking #158 - S/O 2002 has a couple of articles by Steve Brown. He also showed up on Rough Cut showing his compound angle method. Norm covered it too.
Tony
roger lance
Ron.....I just saw a cradle with splayed sides and dovetails on lumberjocks....might be worth a look....
http://lumberjocks.com/paratrooper34/blog/26455
http://lumberjocks.com/projects/66891
Tjanks
RonHarper
Thanks
