Another bench appliance
Ron Harper
Dovetail paring jig is next on the list
Ron Harper
You got your Moxon !!
roger lance
Ron.....congratulations on finishing the Moxon.....hope you get a lot of years of great service from it.....I've really been liking your recent shop photos.
Nice work
What are the screws? Did you use veneer press screws or some such?
You might consider a steel or brass washer under the handles on your screws to reduce wear on the wood (maybe there's already one there and I can't see it).
Bill i am lookin
Ron Harper
I do want brass washers. Yes.. Veneer press screws form Rockler.
Re: Bill i am lookin
Rockler says the screws are 11/16" in diameter (maybe they're metric, and actually 17mm). This is an odd size by modern (inch) fractional standards. You might be able to get 5/8" washers and file out the hole a little. This is not as bad as it sounds - washers tend to have oversized holes, to make installation easier; McMaster-Carr lists its 5/8" washers as having a 0.68" inner diameter; and 11/16" is just 0.6875", so you'd have only a little filing to do.
I'll have a look next time I'm at my fairly-well-stocked hardware store.
Dovetail paring jig
Hi Ron
That Moxon vise looks excellent. Now we want to see examples of it in use!
Regarding the dovetail paring jig you mentioned, there are two on my website. Very useful, especially for baselines of pins which can stretch out. Of course, once you are more practiced a simple undercut at the baseline can enable clean and straight edges there.
A block of wood clamped over the edge of the baseline works well. Adding bolts makes this more versatile.
Here is a link to the first jig I built: http://www.inthewoodshop.com/ShopMadeTools/AJigforParingDovetailBaselines.html
If you can`t find them locally...
Bob Hackett
Email me with the major diameter of the press screws you`re using. I may have some heavy marine grade bronze washers I can bore to fit.
Re: Dovetail paring jig
Ron Harper
I had one of these over ten years ago. I have no idea what happened to it. I do remember very well that the quality of my dovetails went up when I used it. I am not particularly a fan of undercutting. I think working to dead square is better practice.
Again, thank you so much for being so willing to share your learnings from your experience.
Ron
Undercutting the baseline
Hi Ron
When I wrote "undercut the baseline", this is what I meant ...
Then you can pare/chop away the remaining waste ...
Link: http://www.inthewoodshop.com/Furniture/DovetailBaselines.html
Re: Undercutting the baseline
Patrick Gibbons
Thanks for clarifying Derek. I misconstrued your meaning until you posted this.
Now I am with you
My hardware store failed me (and you)
Their brass washers stop at 1/2". Bob Hackett's offer is a very generous one, though; maybe that will be your solution.
William Duffield
If you had used my methodology, you would not have needed brass washers, you would have saved substantial outlay for hardware, and you would have found everything you needed at your nearest Borg or Ace (a real hardware store), for about $11.
