Where to Buy Shooting Boards?
Bart Goldberg
Does anyone know of a source for decent quality shooting boards?
Thanks
Bart
Bart Goldberg
Thanks
Bart
Your scrap pile is a great source.
Tico Vogt
Evenfall Studios
Derek Cohen
I agree with Roger
Ron Harper
This is a pretty easy to make accessory.
I do agree that the new gizmo from Evenfall is way cool, but you can make one yourself and spend what you save on a couple of very nice old tools.
I made one recently. Took me 30 minutes and a big part of that time was deciding which scraps to use.
spot on
Bill Tindall
I was going to post a picture of mine, but other than scrap selection it looks exactly like yours. What do you suppose someone would pay for two pieces of scrap plywood and a stick for a fence?
Make your own ....
Hi Bart
As with many tools, a shooting board can be as simple or as complex as you wish. Not everyone needs or wants a Holtey smoother or a Porsche. Others derive part of their enjoyment that way. All are going to get you there. It just depends on how you wish to travel, where this ranks in the grand scheme of things.
A shooting board may be as simple as a 1/4" layer of MDF with a fence. You do not even need a base if your bench is flat. MDF and Ply can make a decent shooting board in under 10 minutes.
The one below is a variation of the plan from Lie-Nielsen ..
http://www.lie-nielsen.com/pdf/Shooting_Board_And_Fixtures.pdf
By contrast, you can build one that is a piece of furniture in the shop. The performance may be better - or not - but is fun to own and use.
I have a number of articles on my website. Start with this one (all you ever wanted to know about shooting boards but were too afraid to ask
http://www.inthewoodshop.com/ShopMadeTools/Setting%20Up%20and%20Using%20a%20Shooting%20Board4.html
Re: Make your own ....
Ron Harper
After you had cut the pieces for your donkey's ear. How did you handle the assembly to make certain that everything was as it should be?
Ron
Thanks Everyone!
Bart Goldberg
I have been very unsatisfied with my power tools for making clean accurate miters, and I have some decent LN hand planes that I can use if I had a shooting board. I intend to cut my miters on my table saw, then clean them up to be near perfect with hand tools. I am not a big fan of making tools myself, as I have limited time, and rather spend my time building furniture then tools. Hopefully the tools I purchase will be more accurate than the attempts I've made at making my own.
Make it adjustable ..
Hi Ron
The secret to accurate is adjustability. It is impossible (for me at least.
) to be 100% accurate with fences. So I just add in the facility to fine tune everything.
First build in adjustability to the fence. The near end has minimal tolerance. It must not move. However the far end has adjustability via an oversided hole ..
Both a mitre and donkeys ear fence connect via a bolt through the main fence. This provides both a solid connection plus micro-adjustability for squareness.
Drill in a screw underveach corner of the donkeys ear. This will enable you to adjust it in three dimensions for a perfect interaction.
Add nonslip to all fences - I use a little castor sugar sprinkled over varnish. This is especially important on mitre fences. Then add a "runnng fence" to prevent the plane moving away from the side of the platform.
http://www.inthewoodshop.com/ShopMadeTools/RunningFencefortheShootingBoard.html
Now you are in a position to adjust angles and set them exactly as you desire. Plastic squares are incredibly accurate and useful for this purpose.
Very helpful. Thanks
Two comments
Bill Tindall
"I have been very unsatisfied with my power tools for making clean accurate miters"...... A common problem and indeed a shooting board, or a donkey board (which has not been mentioned, is the solution to this problem- shooting board for one kind of miter and donkey board for the others.
"I have some decent LN hand planes that I can use if I had a shooting board." Depending on what you have you will be more or less satisfied. In any case you will learn to sharpen to the highest degree of refinement or you will have difficulty cutting. Personally I find the Lee Valley low angle jack plane idea for shooting miters. It is heavy and it has places to comfortably grab it.
" I am not a big fan of making tools myself, as I have limited time, and rather spend my time building furniture then tools." ......I regard these devices as jigs not tools and philosophically there is a world of difference. While craftsmen seldom make their own tool they typically do make their own jigs.
" Hopefully the tools I purchase will be more accurate than the attempts I've made at making my own."......Not intending to be rude or unkind but if you can't stick two pieces of plywood or MDF together and fix a stick to it at right angles, or 45 degrees, you are a long way from being able to build furniture. It was not an exaggeration to say that making a shooting board is a 30 min job.
In any case, you are going to find that you need to make angles slightly more of less than 45 degrees to fit the miters. I know, in theory everything is 45 degrees but it doesn't turn out that way. To that end, an on-the-fly adjustment of the angle will be useful. It can be done by shimming, as illustrated in the picture. The vertical piece of veneer is adjusting the angle a bit. I have a selection of shims of various thickness (various pieces of plastic) for this task. (shim is exaggerated to illustrate the effect)
