Re: Question about stringing sizer
Wiley Horne--So. Calif.
Hi Bill and all,
Well, to be fair to Lie Nielsen, their thicknesser does not exactly cost a fortune. $65. I think that's an OK price, myself. And it's a good unit, like all things LN. I bought one when they came out, ironically after doing my string thicknessing the hard way, with plane, scraper, and micrometer.
Anyways....you can make something functionally similar yourself, all right. But you need to see it up close. Because the cutter prep is important. Thom described it correctly, with the cutter entrance opened up a little, so you can progressively thin the string. A picture is worth a thousand words:
http://www.flickr.com/photos/78661951@N07/8063421832/in/set-72157631713450111
The problem of making the thicknesser is that--if you start from scratch--you'll either have to start with unhardened steel and drill it unhardened, then harden it; or else do all the stuff ya gotta do to drill hardened steel; or else take the hardened steel to a local machinist for slotting. Bob offered a 'no drill' solution, which sounds good to me.
It strikes me that the truly simplest way is to use a slotted plane blade, or else a chisel plane directly as shown in one of Thom's links. If you use a plane blade, the letting-in is pretty simple--a big shallow rebate.
I'll mention one other thing, but of course you would think of it yourself. And that is, that the thicknesser will need to be adjustable enough to match the channel cut by your stringing router. For example, when I did my strings, I used a stringing router which my friend Konrad Sauer (a truly great craftsman!) was kind enough to make and send. Konrad had attended a class by a very well-known furniture maker, and he made me a router like the one they made in class. Here it is:
http://www.flickr.com/photos/78661951@N07/8063422865/in/set-72157631713450111/
and here is the other end, showing the threaded insert that the thumbscrew goes into:
http://www.flickr.com/photos/78661951@N07/8063421627/in/set-72157631713450111/
That's an ordinary fragment of saw blade that he used to fashion the cutter. Now here's the point I want to get to: the stringing router blade has a slight taper to it. So when I made the strings, I scraper a slight taper into them also. Long story short: make sure the thicknesser has enough flexibility designed in to match your router.
One other thing I should mention. Konrad said that the router tooth has to be fashioned quite precisely, with four sides square and real sharp, and the little tiny bottom has to be square and sharp also. Cause you're gonna use this thing in both directions, depending on how the grain lays. So although the tool can be any fragment of hardened steel, the prep is critical.
Wiley
